converting to piezo gyro help
I need pictures how to put collet and what remove from arlton gyro.
thx Peter |
you need to remove all of the arlton gyro down to the pitch slider then put the collet through the slider from the rotor side and then put the set collar on from the outside I hope I have not confused you.
Pic
1 Attachment(s)
The mod kit from LMH is like $8. :confused:
For a longer Eyelet and a wheel coller. You might try something like a pop rivit and drill the hole you need in it. :D |
Hey, hahaha I got one of those too! the kit to change it over and the gyro.........!! :p
| All times are GMT -8. The time now is 10:02 PM. |
