Flight!!
Is there any way i can make this thing do loops or fly upside down ?
Has anyone tried putting a wireless cam on your heli? Dropping eggs and using rocket engines as missiles is not fun anymore :( :stupid: |
Flight!!
Loops are possible, with a lot of altitude (So I've read)
Inverted flight is not, that requires negative main rotor pitch. LMH's are fixed positive. |
Re: Flight!!
Originally posted by Sonic Is there any way i can make this thing do loops or fly upside down ? Has anyone tried putting a wireless cam on your heli? Dropping eggs and using rocket engines as missiles is not fun anymore :( :stupid: I must try that! |
FunFun
I got a 6 channel radio, i use 2 servo to launch the eggs and fire the rockers ( the rockets are trigger an by eletrical charge)
At fisrt I tried with water ballons but those where too heavy. Fully loaded i can carry 4 rocket engines and 3 eggs ( yes, it still gets off the ground) The hard part is getting 2 servos to do so much. Sonic :D |
Flight!!
You got to give us some photos or movies of that!
Flight!!
What if we took the electrics from the fighterbirds and put them in LMH. Then we could dog fight.
Flight!!
http://www.hobbyzonesports.com/produ...ductID=HBZ4020
Plug in the Sonic Combat Module and take on similarly equipped HobbyZone planes in aerial combat. When “hit”, the SCM temporarily disables your opponent’s motor for ten seconds while still allowing them to steer. This would be like shot down for real in a heli. And only in a LMH would you even think about it. Would only work in Corona's and E-LMH'S |
| All times are GMT -8. The time now is 05:40 AM. |
