help
I just picked up a second hand lmh110 it had a telebee gr 703 piezo gyro with it just not mounted first where do I mount it and also when I pluged it all in my tail rotor only worked in one direction when I moved the stick is this right or not I need help no one around here has helis
help
K3
Welcome to the hobby. I think you will get a lot better response if you ask specific questions, provide a good description of your problem, and most importantly type clearly. From what you have posted it is impossible for me to even begin to guess what is going on at your end. Start off by going through the entire building manual and checking that everything is set up and adjusted correctly. The manuals are excellent and address many of the problems we see here. The same thing goes for your gyro. I do not know anything about that particular model, but I bet it has some very decent instructions as well that will most likely answer your questions. When you have figured out what it is you would like to ask, feel free to try again and a bit more clearly. Spiro |
help
cool,
try these links: http://www.rotory.com/ubbthreads/sho...b=5&o=&fpart=1 http://www.rchelibase.com/gyro/telebee.pdf http://www.ronlund.com/telebee_setup.htm Some pretty good details on the Telebee 701 gyro operation and installation. The 703 is similar but for slower servos I think. Good luck. |
| All times are GMT -8. The time now is 08:31 AM. |
