Aftershock NO 4wd PLZ Help
AZ
Hey guys I recently got hooked up with an Aftershock. It had been sitting for awhile before I got it. I went through the electronics and engine and Finally fired it today. It ran great BUT it didnt have 4WD. Only the front wheels spun. Any ideas on what is causing this?
On another note If I spin 1 wheel in the rear the other barely spins at all
Shawn
Shawn
RE: Aftershock NO 4wd PLZ Help
ORIGINAL: SMOKEFAN
Bueller.........Bueller
Should the grub screws not be the culprit, I'd then look to the Diffs. If the front wheels were spinning then the transmission sounds fine internally.
NY
I broke all 4 diff outdrive cups before upgrading to the hd ones, it's possible that you have one broken. You probably won't see it though, mine all looked like they were still together.
AZ
Okay guys The outdrive from the transmission does NOT have a set screw in it. So I am assuming this is my problem. Does anyone know what size of screw that is or a losi part number.
Thanks for the replies and help I appreciate it.
Shawn
Shawn
