Tires and Rims
FL
Tires and Rims
I am wondering what tires and rim combos you guys are using, my tires and rims are starting to bite the dust and I was just going to look for a new pair. I have both 17mm hexs and 20mm and I ususally run on sandy dirt and clay most of the time... what do you guys think???
RE: Tires and Rims
Sand and clay are opposite ends of the traction spectrum if you want optimum tires. You can usually run a sticky, low profile tread in clay whereas in sand you want an aggressive tread. Stock LST2 tires or XXL tires are good for clay. I would recommend 40 series Proline trenchers on some split 6 wheels for the sandy stuff.
RE: Tires and Rims
ORIGINAL: mkruse
I was looking at the proline 40s just didnt know how they would be on the lst
MI
RE: Tires and Rims
Stock losi 420 series wheels/tires are same size as proline 40 series. Bashing duties I would use 40 series, Racing duties I would use a truggy wheel/tire. You will need 17mm hexes for truggy wheels.
