new to losi and bought used yuk
i have a after shock and has a new dynamite .28 ....the blue head version. M28 and i can get it to fire but as soon as i give it gas it dies. If its there running at high idle from the transmitter and i hit the brake it dies almost like if the truck stops rolling it stops the motor. So yeah im not sure what the heck is going on.
RE: new to losi and bought used yuk
ORIGINAL: reddogracing
ive also just noticed i have no brakes...all tje parts seem to be there and servo arm is swinging and its adj as far as it can go...any ideas lol. I hate buying used haha
Chances are that if you readjust the throttle/brake linkage to be in the correct orientation, you should be able to get the idle speed set and get some run time on the engine to break it in. Every engine needs a slightly different linkage configuration so adjusting the linkages for a new engine is a must.
1QwkSport2.5r thanks alot. That worked perfect moving it out to the other hole. I think i messed up the same msg im writting now some how i hit report not reply but when admin sees it im sure theyll no it was a mistake but yeah almost all the bugs r worked out. Ive got brakes my truck will idle now ....he had the idle 100% closed but all is good short of i got the motor set to factory but it will run for 30 to 60 sec then die after that it will fire a few times then its done. Almost like a fuel rest, or maybe just my needle settings. When it runs its got great throttle till it dies. I may have it to lean even at break in...it dont help its 20 degrees outside
Get some run time on the engine. That engine will break in real nicely. Readjust the idle speed when needed, and after 8-10 tanks of fuel you can lean it down for better power.
this may sound stupid but when i pull the fuel line from tank to exhaust should i be able to blow air though it? Seems like on my traxxas motors i can but on thos one it feel lile its restricted blowing on the tube that run to the exhaust.tje motor just acts like it runs off the primed fuel then when its gone it dont wanna run anymore. But tank and lines ar mew and clear
Pull the pressure line off both the tank and exhaust and blow through it. If no air goes through, replace that section of tubing.
yeah the stupid pipe had so much crap inside it,it blocked the pressure zirt coming off the pipe. Got pretty much everythong ironed out on it but trying to swap wheels and tires and the idiot who put the wheels on has the rf on so tight that my socket is starting to click as i have to apply so much pressure it making the socket spin. Jesus ill think long and hard before buying another used truckzilla made up of a scrap yard of parts.
ON, CANADA
Ah the fun of used equipment. I went through a good list of replacements on a LST I had purchased used two years ago; from a new main plate to new stearing links. I enjoy the build and problem solving so was lots of fun getting the beast up and running. Unfortunately had to sell it to pay some bills this past fall, even manged to get a new RC boat out of the deal. Would defiantly get another used one may do an electric conversion on the next one.
I've bought a few used cars in the last 5ish years. The first LST2 and parts lot was a great bargain... 2 trucks for the price of one. Then the basket case jato and nitro rustler for $40. Wrecked the rustler on a 2.4GHz runaway. Failsafe = no worky. Still working to rebuild it... I love my 3.3 powered rustler.
now my big issue is i need to swap tires and wheels and the rf is sized on there. It flat out wont budge. Ive had it sitting for about a week and i keep spraying pd blaster is it which is the best stuff i know of when it comes to bad nuts and bolts but i can put so much pai on it the socket will just round. I still have good bite on it right now but trying to find a 8point socket thats 1/4 inch drive cuz the wheel is so deep i cant use a 3/8 drive but im thinking either drill it out or leave it be
The tires and wheels are brand new but just wanted to use something different that and when i break something on it ill have to get that wheel off at some point. This sucks
http://losi.com/Products/Features.aspx?ProdId=LOSB4603
I have many suspension and axle parts for an Aftershock in case you need them.
BTW: You do know that one side of the truck has Right Hand (RH) nuts and the other side is Left Hand (LH) nuts? Righty Tighty Lefty Loosey on one side, opposite on the other.
yeah i got that tool and ive tried nut drivers and 8mm sockets 5/16 sockets ive tried 6 point and 12 point i need a 8 point but cant find one in a 1/4 inch drive. I thoughy about the pencil tourch but afraid ill melt the wheel. Id post a pic but im doing this from my phone and i cant get it to work. Ill upload the pic in my gallery and thats the only thing i can do from mobile
yeah got all three off. Ive been using a rachet and i get enough tourqe to spin the socket. If i could find an 8 point id have less rounding. Im a auto mechanic by trade and 8 point is what i use when i have a rounded or rounding nut but cant find one small enough but when i get home i will try heating up a socket and let it sit to see if that helps
Heat the socket up as hot as you can, and stick it on the nut to heat the nut. With a little luck, it will come loose. If the nut is completely rounded off and you cant get it off by using the above method, you're better off sacrificing the wheel and hit the axle stud directly with the torch.
Are you aware that the aftershock has got left handed threaded axles on one side of the truck?
Perhaps this is the reason the wheel nuts won't come off.
ORIGINAL: sparky 25
ORIGINAL: 1QwkSport2.5r
