serial #
serial #
Sorry for the dumb question, but where could i find the serial number on my LST so i can determine if that washer is in there. Thank you.
RE: serial #
I would take the time to remove the backplate from the engine and look inside rather than just going by the manufacturing number. It's not worth the 10 minutes of hassle it takes to check inside.
NE
RE: serial #
heat them up with a hair Dyer/heat gun and take them out u should be able to get them far enough out before they strip to grab them with a needle nose pliers
Banned
ON, CANADA
RE: serial #
ORIGINAL: Snikkari
Why dont they have hex screws insrtead of Phillips for the backplate, thats really dumb.
They are too easy too strip
Banned
ON, CANADA
RE: serial #
ORIGINAL: creyc
What size screws are these and is the a direct screw on this truck someplace that would fit? I'd like to order some from Horizon.
2.5x7mm Hex for Roto cover
You should find them at your LHS.
