Aftershock...
AZ
Aftershock...
So, I've been so focused on the LST2... and my procurement of one... that I've totally skipped out on the Aftershock. Are there major differences between the Aftershock and the LST2? I'm getting some extra money in the next month or two... I'm finding it really hard to justify the cost of the LST2... let's face it... spending $600 on a R/C truck is a rather large pill to swallow... so, my question is... is the Aftershock as good as the LST2? It would be much easier to get $350 approved by the wifey than $600... [X(]
ON, CANADA
RE: Aftershock...
IMO the LST2 Drivetrain Parts are Well worth the Extra Money alone......Then there the are 2speed Gears/Radio/Tranny/Engine/Pipe.....Belive me You'll Spend More Up-Grading an Aftershock than what it Cost to just get the LST2.......
Heres a few Pics from 2D,
Right is LST2,left is Aftershock
Left is LST2, right is Aftershock
Aftershock LST CVD vs LST2...
LST2 CVD pins are captured by this large bearing.
LST2 axles are 8mm like a 1/8 scale buggy..
LST1/Aftershock hex pin compared to LST2
LST1/Aftershock rear carrier compared to LST2
LST1/Aftershock axles compared...
Rear wheel of my LST2 after it was ran over by a 1:1 Tacoma..
Replaced Tires and wheels and completed a full race program when I got home I checked it out further (night racing or I would have noticed this)
It filed the rear carrier down on the pavement when the wheel was crush, no LST parts failed...
WI
RE: Aftershock...
IMO, the aftershock is a good truck for the price. I have one, the last couple weeks I have been beating the crap out of this thing. I only broke two a-arms (trying front flips) and one siderail (run away truck wide open into a wall) I been jumping it 10-15 feet in the air flat landing it no prob. Been jumping on the garge roof and dropping off (will get pics of that soon) It just needs a new pipe. But yes the lst2 is a better truck for sure.
[img][/img][img][/img][img][/img]
WI
RE: Aftershock...
Is there a website to tells you what parts to make the aftershock arms like the LST2
Like a conversion?
Or does anyone know the part numbers?
Like a conversion?
WI
RE: Aftershock...
ORIGINAL: RenegadeRevo
AZ
RE: Aftershock...
ORIGINAL: RevoVega28
welcome back renegaderevo! I remebr you from a while back.
AZ
RE: Aftershock...
BTW - I noticed that the Aftershock is equipped for the "optional" spin start... what is the non-optional starting method? Does it come with a pull? I don't really mind pull start anymore... I converted. (only out of necessity)
RE: Aftershock...
ORIGINAL: benzzyo5
me too i love my aftershock.
use the original from lst2, as lots of silk dusk still can go in the 2 speed trainy and short life the gear. The gear stay only for about 2 tank in that cover, but after replacing that its stay more than a galon or two.
Also the 2 speed of the lst are better than the aftershock, as the 1st gear of the aftershock is whole assembly together with the one way bearing, if you want to upgrade gears you need to replace the whole enchelada, not like the lst or lst2, as i have both of them, a friend of mine have the aftershock and he decide to change his to lst type so that he could do the upgrade. And if you stripe the gear you don't need to change the whole 1st gear, just change the gear it self.
TX
RE: Aftershock...
I've been using the RPM gear cover since it was first released. I run High HP engines on high silica content RC tracks. I get ~4&6 gallons on stock spurs using TiNi pinions(I don't know how long these last because I have never wore a set out). If you get 2 gallons or less you really need to inspect/replace your engine to chassis brace and/or correct the mesh.
TX
RE: Aftershock...
If occurs to me that maybe I get such long life because I have all LOSI HP plates making for a much stiffer chassis but 1 gallon on the stock spurs and I still say you have a cracked engine to chassis brace and/or bad meshing skills... I never strips spurs ever, most people would continue going with units I replace.
AZ
RE: Aftershock...
So, it comes with a pull... hmmm... I'm going to have to discuss it with the boss (wifey) ... I think an aftershock may be my best bet right now... if I can only convince my wife it's a good thing... [X(]
MI
RE: Aftershock...
The LST2 is a boat anchor, unless you’re trying to jump the truck over your garage the Aftershock is a more realistic truck for the money!
P.S: Once you break the pull start rope and are forced to install the spin start you will never go back!
RE: Aftershock...
She's tough. I blipped the throttle a little too hard at the top of a 30ft bank and sent it doing about 8 'endos', down the bank until it reached the gravel parking lot where it did a couple more and landed on its tires, still running. The only damage was to the body of course. The only time I broke an suspension part was when the right front tire smacked a tree.
If you don't mind reading the exploded drawing you can figure out the differences between the AF and LST2.
page 20 and 21 of the AF manual and page 7 and 8 of the LST2 parts explosion for the suspension differences. You can get the spin start cheap off of ebay.
AF
http://www.teamlosi.com/ProdInfo/Fil...hock_final.pdf
LST 2 Monster Truck RTR w/XS3 Parts Explosion
http://www.teamlosi.com/ProdInfo/Fil...osion_LST2.pdf
Hope the links work. The AF has the LST's suspension, doesn't have the HI/LOW/Reverse that many racer's take off anyway, and it has the upgraded alum diffs that the LST2 has. Its a better truck than the LST. I love mine.
Chris
AF
Chris
NC
RE: Aftershock...
You could always go with the LST2 upgrade kit a little later on. The Aftershock package certainly has it's advantages when a budget is involved, and you can spread out the cost a little more, but you come out ahead just biting the bullet and getting the LST2 to start with.
The $350 Aftershock + $140 upgrade kit + $45 for 40 series tires = $535 and you will have a LST2 minus the FM radio and Mach 427 engine... So, the $580 for the LST2 isn't that bad when you think about it.
Also, didn't I read on here one time that you were still using the stock Traxxas radio for your Revo? Well, if you get the LST2 you can always just buy an extra RX for the Revo and use the muuuuuch better JR XS3 for both trucks.
AZ
RE: Aftershock...
I'll stick with the AM radio for my Revo... I don't mind it... it works quite nicely... (that way if I'm out with buddies... my Revo can be run at the same time as the Aftershock/LST2)
With those things you did point out.... I'm not quite sure what I want to do now... LOL... I was sold on the Aftershock... but now I'm doubting. I'm not going to have the money for a while.. and that's only if I can allocate the money towards R/C... so, I still have some time... but I want to know what I want before I get it... ya know? I know it'll be one of the Losi models... just not sure which one.
Perhaps I'll stop at my LHS to compare them... I'm really sold on the LST2... and I'm worried that if I get an Aftershock... I'll wish I would have bought the LST2...
NC
RE: Aftershock...
Hey guys, new to the Forum, but not to RC. I have had my AfterShock for 1 year now, I was shoping for a LST2, but while comparing the 2, I decided the things that were downgraded on the Aftershock were the items I would upgrade on the LST2 anyway. I drove the truck for 4 months before breaking an A-arm (wide open off a ramp side ways into racing stand! seeing it fly all crazy tumbling through the air was woth the $14 for the RPM replacement arms (I went ahead and spent the extra 45 and got RPM arms all the way around). I have beat, banged, landed off jumps nose first, you name this thing is hard to break! Also, it can be converted a little at a time to a LST2, if money is the concern now, it may be easier to upgrade items as they break! Not that you need to upgrade right out of the box. It is easier to spend out 30 or 60 bucks as needed than it is to spen $350 more to start with. Stock LST2's are better, but I doubt you will notice any difference in performance, I still kick the crud out of my neighbor's Revo!
