Whats a good Mid Range Pipe For The LRP Z.28R Spec 3
RE: Whats a good Mid Range Pipe For The LRP Z.28R Spec 3
or if you want to spend more money you can buy a JP-1 exhaust
Edit: the HT pipe is a great exhaust. But for some reason it seems to get kinda hot.
I've got to agree with 2DMaxLST, the LST2 stock pipe gives you great mids range. I just tried the LST2 pipe a few days ago from a cen matrix pipe (I just had to run my 8t with something). The LST2 pipe gave a better mid-top power curve but the temp went up a bit also. Go with it, I've seen many people use it to with good results.
I have a jp3 with my axial 28rr right now and I would like to use the jp3 with the lrp as well(I'm getting it in 2 weeks). Anybody have any idea how well the jp3 does?? does it cut down temps and does it provide that proper mid range boost that its known for.
CA
I have to say this pipe pulls alot of power out of this engine I run a 13 tooth with max life clutch shoes and it make my tires look like Xlrg pizzas.."LOL".........[8D]
ORIGINAL: coololdude
Same thing with my tires, When you put thicker clutch springs in those Max-lifes clutch shoes, the engine also SCREAMS more [>:]
