Aftershock will not start!!!!!
NY
This nitro stuff not starting is getting really old now. I had it running for about 5 seconds and died. Now the damn thing will not start at all. NO matter what i do. I have taken out the glow plug and it is red hot. Only thing i can think of it is the crap nitro from the other nitro i got is not worth a ****. So any idea's on how to get this to run please let me know.
NY
RE: Aftershock will not start!!!!!
ORIGINAL: dudecat
I actually had the same problem with my aftershock, it started up the first time ran for 15 seconds tops then died. After that it would just spin over. Never did find out what the problem was, I ended up tossing the motor, put an lrp .28 in its place. The took the lrp out and put another mach .26ss in its place and sold the whole thing. Never did actually run the Aftershock. So it was still brand spanking new when I sold it.
NY
Well it started again ran for about 1 minute then i pushed the throttle and died. I am assuming the glow ignitor needs more charging i guess.
if it ran for a minute then stalled when you trottle its probably too rich ... maybe someone else will have a better solution but i would try this
VA
I have noticed that on break-ins the stock c cell igniter is better than the rechargeable the stock takes a alkaline battery that sits at 1.5v where as a rechargeable sits at 1.2v, keeps the plug a little hotter and leave it on through most of the break in until you start to lean it out it helps with stalling.
NY
Well i got it running!!! Ran out what little nitro i had so now i have to wait and buy some nitro. Trucks runs like it is on steroids though
NY
Today i killed the first glow plug. Is this common when running them in the cold? I put aluminum foil around the head to keep the temp higher.
MO
ORIGINAL: dudecat
Around 20f outside when i was running it.
Sorry I meant the motor temp, keeping the motor tuned properly and at the right temp with increase glow plug life.
