Broke my Aftershock :(
NY
Yep today i was bashing with it and my clutch bearings on the motor went and cost me both plastic gears on the transmission. So now i have to buy clutch/bearings/gears before i can bash again. So now it is going to sit on the bench t'll i get enough money to fix it
RE: Broke my Aftershock :(
why do you have to buy a new clutch bell, if yours is fine dont bother buying a new one because thay are expencive. The bearings and spur gears shouldnt cost you alot...
QC, CANADA
Clutch bearing, on a 2 speed truck like the LST should be change very often.
I order a bunch of bearing at AVID RC, 1.00$ each, and i change them each 1/2 gallon.
Or, you can put a third bearing on your clutch bell, and the bearing will last long time.
But for $1.00 each, i change them often
NY
Yeah the clutch bell housing is fine just the internal clutch of it is shot and the bearings.(plastic parts) I will defently look into the bearings you listed there. Good to know i should keep a close eye on them in the future. I was thinking about going all metal gears and metal clutch shoes but will that do damage to the transmission/bell housing? So yeah lesson learned the hard way i guess.
QC, CANADA
You don't have to go with steel spur.
If you maintain your CB bearing in good shape, your plastic spurs will last long time.
ORIGINAL: dudecat
get the losi long wear aluminum clutch shoes, and every 1/4 gallon or so brake clean the clutch shoes and clutch bell and they will last a long time.
NY
ok buying the gears and clutch off of ebay this weekend. I need to find the bearings for this clutch. So where is the best place to buy the bearings?
http://cgi.ebay.com/CLUTCH-SHOES-LOS...item5ad6aa9d06 - shoes for the clutch
http://cgi.ebay.com/Losi-LST-Aftersh...item3ca8db014c - extra battery pack and charger
now i need to find the gears and bearings. Any good places to go for these parts?
PA
OH
ORIGINAL: dakamat
ON, CANADA
im not 100% sure but i think you should use metal sealed bearing because of the high heat clutches make
thats what im using
thats what im using
NY
Thought i would post the damage my bearings failing did lol.......
bearings when i took them off the engine not looking good at all
another picture of the bad bearings
Look at the clutch missing a piece of the plastic shoe
another look at the bad shoe
rest of the shoes look fine - i am replacing them with metal ones
yep these have had better days
So yeah looking around $60 to repair everything.
NY
Alrighty bought all the parts i need to get her back up and running. Only $40 with shipping. Not bad considering i sold some stuff and a guy owed me some money paid some of it off so i could get my parts.
Parts i bought were new gears(w/hardware)/metal clutch and these bearings: http://www.avidrc.com/product/?c=1&p=1 (bought six of them to make sure i have enough for awhile). So hopefully this weekend coming up the parts will be here and i can get her up and running again.
