Diff Shims
I think I will need shims for my diffs since I'm getting the upgrade kit for my LST. What set do I need? The set with 5mm/6mm shims or the set with 13mm shims?
RE: Diff Shims
What upgrade kit are you referring to?
RE: Diff Shims
ORIGINAL: Mclovin350z What upgrade kit are you referring to? http://www.losi.com/Products/Feature...rodId=LOSB0014 I used this kit to upgrade my (now stolen) Aftershock to LST2 spec. The only parts that don't come in this kit to make it an official lst2 is the 2spd hubs, and throttle/brake linkage AFAIK. As far as shims go, you'll need both sets. 6mm shims for the pinion and 13mm for the diff itself. I bought the 5&6mm shim set (Losi LOSA6356) and 13x16x.20mm shim set (HPI 86598) to shim the diffs and transmission on my newest LST2 (scratch build from spare parts). The only reason I bought the HPI set is a) it was cheaper and b) they were out of the Losi ones but they are the same thing anyhow. There is a how-to on shimming LST2 diffs here: http://hdrcvideos.com/forums/viewtopic.php?f=18&t=15378. If done right, they will last a long time. One other thing - The upgrade kit comes with new chassis braces. When I was going to put them in, they ended up being the same identical braces that were on the Aftershock so I didnt change them. I didnt swap the transmission case either because the Aftershock already had the Forward Only transmission. If you do a FOC, the FOC kit comes with plugs for the trans case where the high/low selector and reverse linkage would go. |
RE: Diff Shims
^^^^^^Thanks man that helped a ton!!!!!!
RE: Diff Shims
Will the 5mm/6mm actually be used on the diff though? I mean if not, then I won't get it, and in the how-to, there was nothing that had to do with 5mm/6mm shims.
RE: Diff Shims
ORIGINAL: nitrojimbo Will the 5mm/6mm actually be used on the diff though? I mean if not, then I won't get it, and in the how-to, there was nothing that had to do with 5mm/6mm shims. |
RE: Diff Shims
Thanks again!! I'll keep that in mind.
