lst reciever packs
forgive me.. I'm an RC newb.
after my AA batteries died during the 3rd tank I figured I'd make a run to the lhs (an hour drive!) to get a rechargable cell pack, I didn't find any that would connect to the lst harness. The owner wasn't much help either. So my question is what flat packs will connect? or do I have to rewire the truck or use some sort of adapter? told ya i was new! The hobby shop owner insisted that the Reedy 5 cell would fit.. so i bought it and its got the wrong connection on it. Please help this old guy out! I want one that will last at least 6 tanks of fuel. |
RE: lst reciever packs
you need a different on/off switch.. the one the losi has is the small (BEC) red plug.. you need to get a jr on/off switch with a standard black plug...
this is the one i use..it has a extra charging wire so you dont have to unhook your battery! [link=http://horizon.hobbyshopnow.com/products/description.asp?prod=JRPA003]on/off switch[/link]
ORIGINAL: fantomas you need a different on/off switch.. the one the losi has the small red plug.. you need to get a jr on/off switch with a standard black plug... I read the other threads on the same subject and it seems everyone is either making custom setups or using the 7.2v |
most packs have the standard black connectors, but this is the pack that LOSI suggest to use with the LST [link=http://horizon.hobbyshopnow.com/products/description.asp?prod=DYN1431]dynamite battery link[/link]
that one has the red (bec) connection... so its a direct plug in
thanks.. now I have a couple of options at least.
ever heard of anyone stuffing a hump pack under the fuel tank as well as the flat pack so you could just swap connections quick then just recharge both later.. or is that just a dumb idea? |
at 600mah, that dynomite doesn't seem like it would last too long.
no its not i bad idea.. i do it when im just bashing around, but for racing it just add's more weight... so i guess it just depends on what your doing with the truck..
at 600mah, that dynomite doesn't seem like it would last too long. |
I just ordered the switch! I'll probably go through a bunch of AA's waiting for it to get here!
yea this truck eats up the AA's.. :D
i use a 1100 hump pack, 1200 ofna flat pack , and a 1400 flat pack.. Do you have a link to where you purchased your 1400 mah rx stick pack? Did it have the correct red BEC connector already on it? Does it fit under the LST without a problem? Thanks in advance... -Stevie D |
The 1400 can be purchased at Horizon. No, it doesnt have the BEC style connector. Take Fantomas advice, and buy the switch. The only batter i've seen that comes with a BEC connector is the dynamite. Its not the standard, and its not the biggest battery you can buy either. So when you order the battery, order the switch harness too. You can buy them both at Horizon.
ORIGINAL: Stevied53 i use a 1100 hump pack, 1200 ofna flat pack , and a 1400 flat pack.. Do you have a link to where you purchased your 1400 mah rx stick pack? Did it have the correct red BEC connector already on it? Does it fit under the LST without a problem? Thanks in advance... -Stevie D |
I got the switch installed today. the part # of the unit is JRPA003, less than $10 at Horizon Hobby
thanks guys! |
you can make a 2300 AA nimh pack cheaper than buying one from your llhs store if you live near walmart.
Yeah but it wont fit under the truck and it will undoubtedly add unnecessary clutter.
This battery pack will fit perfectly under your lst. It's connector is also an exact match.
http://www.onlybatteries.com/showite...temID=12505.58 |
Anybody have a link to a hump pack that will fit under the fuel tank? The matching connector would be nice but not necessary.
I am using an HPI 1200 mah hump pack (left over from my savage that I should have kept) under the gas tank. It lasts me four tanks of fuel.
after spending far too much time charging, I installed both a 1400 mah hump under the tank and a 1200 stick (under chassis) connected via Y harness - http://www.horizonhobby.com/Shop/ByC...ProdID=EXRA310
total capacity of 2600 mah - nice! |
ORIGINAL: marksp after spending far too much time charging, I installed both a 1400 mah hump under the tank and a 1200 stick (under chassis) connected via Y harness - http://www.horizonhobby.com/Shop/ByC...ProdID=EXRA310 total capacity of 2600 mah - nice! There was a big debate over this. It works with no complications? How long (tanks)have you been using it??? |
no issues so far...honestly, I just did this weekend, and haven't had to re-charge yet. I was getting ~ 4 tanks per charge on a 1100 mah hump.
ORIGINAL: marksp no issues so far...honestly, I just did this weekend, and haven't had to re-charge yet. I was getting ~ 4 tanks per charge on a 1100 mah hump. |
