RS 300 reciever probs
my reciever voltage is rated at 4.8 how do i change it to 6 volt. How i found out was i put a voltage meter on my LST2 with a fresh battery and it read dead batery. I switched it to 4.8 volt reading and it was reading full battery. We did some other testings wit other recievers and bateries and all combo's read good. I looked up the servo info and thay state that the rs 300 is rated at 4.8 or 6 volt how can i change this if there is any way without having to switch out servos?
RE: RS 300 reciever probs
If your inputting 6v and only getting 4.8 out of receiver, then you can simply get a y harness and run your battery to one of your other channels like steering or throttle. Plug servo lead into one side of y and battery into other and plug "stem" of the y into proper servo channel on rx. Good luck.
