diff fluid
is diff fluid the same as shock fluid
RE: diff fluid
Yes and no, the shock fluids are the same as the diff fluids only they are a lot lower viscosity (less resistance to moving). Now if you wanted to use diff oil in the shocks you would look at blown caps for sure, as for the shock oil in the diffs, it is a lubricant but the car will handle a lot different [&:]
RE: diff fluid
but when eveyone talks about there diff fluid like 1ok and 7 k what is that and where can i find it
| All times are GMT -8. The time now is 06:16 AM. |
