Reload this Page >
My First Tank – Remade
Old 09-27-2010, 01:01 AM
HondoBob
HondoBob's Avatar
Default My First Tank – Remade
Some of you might recall I started into this hobby with a Heng Long Panzer 3 a couple of months ago. This is how it started:
I’m sure some will recall my feeble first attempt to dress it up with paint and some modest metal upgrades:
And here she is after a major refit: Replaced the airsoft gun with an Asiatam recoil unit and Tank-Modellbau barrel.I also installed a David’s Battle Circuit/David’s Battle Unit (DBC/DBU) to make it Tamiya IR compatible.The turret number decals horribly silvered after they fully dried, so I’ll have to scrape and repaint at a later date.
I also took lots of pics of the recoil unit installation with emphasis on the many mods necessary to make it and the new barrel fit and function properly.I’ll put together another post detailing that part of the project.
Old 09-27-2010, 02:09 AM
Pzjgr
Pzjgr's Avatar
Default RE: My First Tank – Remade
Wonderful paint job and wearthing. Are you coming to the Oct 9th battle with it?
Duane
Old 09-27-2010, 03:42 AM
karel47
karel47's Avatar
nice Pzkfz III man, well weathered
Old 09-27-2010, 04:25 AM
edoubleaz
edoubleaz's Avatar
NIce job sir. I look forward to shooting at you from across the field!
Old 09-27-2010, 06:42 AM
Eggman1965
Eggman1965's Avatar
Actually Bob, your original post inspired me to attempt to paint and weather my Tiger I ! I thought your low cost approach was inspired, using Sharpies to blacken the tires was really creative. This "new" Pzkw III looks fantastic and I like the iron cross on the IR reciever.
Old 09-27-2010, 07:33 AM
YHR
YHR's Avatar
Great Job. Your skills have progressively got better, and that is one fine tank.
Old 09-27-2010, 08:00 AM
Capt.Canuck
Capt.Canuck's Avatar
Looks great, very nice job!
Old 09-27-2010, 08:28 AM
pattoncommander
pattoncommander's Avatar
Final results look spiffy. Very realistic. Are you going to put on a stowage rack?
Old 09-27-2010, 08:45 AM
Buckeye36
Buckeye36's Avatar
Nice job!
Old 09-27-2010, 08:46 AM
1sgt
Bob,
Great looking PZ III. All my tanks are air soft, but I would like to have an IR so I can battle, and if I enjoy it enough, change over some of my airsoft tanks.
As far as the decals silvering have you tried putting some gloss coat on the areas to be decaled ( some have used Futura floor wax for the same thing). The smoothness of the gloss coat lets the decal adhere better. You may also want to cut the numbers apart to do away with the excess decal film. Don't get me wrong, I think your PZ III is great but, you did mention about redoing the decals so I thought I would give something to think about.
Jim
Old 09-27-2010, 09:07 AM
Fireman Tim
Fireman Tim's Avatar
I can tell you had a lot of enjoyment working on that PzIII. That is what this hobby is all about.
It looks great! I want one now.
Old 09-27-2010, 09:24 AM
tankmaster5001
Great looking tank
Old 09-27-2010, 11:26 AM
HondoBob
HondoBob's Avatar
Yep I applied two coats of acrylic floor sealant on the turret, but I guess I should have applied four layers to prevent ruining the ultra-fine Peddinghaus decals.  My bad.  I'll have to remove the turret to scrape and repaint.  Thank goodness the other smaller decals didn't silver up.
I've tested the DBC/DBU with a very nice Tamiya Sherman modified into an M36B1 in winter white wash I purchased from a DAK member, and all systems seem to work fine.  Recoil and muzzle flash are functional, the Heng Long recoil-dance-of-pain is gone, drive momentum is proportional, and speed reduces with successive hits.  This Panzer 3 is evenly matched with a Tamiya Sherman, though I think it has slightly better mobility.  I'll find out when I bring both tanks to the DAK battleground in Phoenix on 9 October!
Old 09-27-2010, 11:43 AM
1sgt
ORIGINAL: HondoBob
Bob,
I forgot to mention decal setting solution. It kinda melts the decal film to the model. You can snuggle decals over bolt heads etc.
Jim
Old 09-27-2010, 04:54 PM
Spitvalve
Good looking PZIII. Accurate gun really changes the look of the tank.
Mike.
Old 09-27-2010, 07:12 PM
Panther G
Excellent job. Some of you guys got the weathering down to perfection. Really nice work.
Old 09-27-2010, 07:20 PM
ksoc
ksoc's Avatar
This is a great post!
Shows the newcomers that they don't have to jump into the deep end, but can ease their way in as time, money, and skill(s) permit.
Old 09-27-2010, 07:33 PM
Panther G
Well said.
Old 09-27-2010, 08:15 PM
torpedochief
torpedochief's Avatar
Very Nice Job!!!
Weathering is top notch!
Don
Old 09-27-2010, 08:25 PM
HondoBob
HondoBob's Avatar
ORIGINAL: pattoncommander
I'm thinking aboutbuilding a storage rack from some oldsmall scale model train track, but I can't seem to find a sufficiently detailedexample to work from. I'm definitely open to all suggestions!
Old 09-27-2010, 09:53 PM
Spitvalve
Hi Bob,
I used brass HO scale railway track for mine. The Prime Portal site has some good shots of the rack on the Bovington PZIII and the Squadron PZIII Profile book has some good shots. Here's the Prime Portal link:
[link]http://www.primeportal.net/tanks/john_griffin/panzer_iii/[/link]
The racks were field lash ups so you've got lots of design leeway.
Have fun,
Mike.
ID:	1507912   Click image for larger version
ID:	1507913   Click image for larger version
ID:	1507914   Click image for larger version
ID:	1507915   Click image for larger version
ID:	1507916   Click image for larger version
Old 09-28-2010, 10:55 PM
HondoBob
HondoBob's Avatar
Thanks Spitvalve for the suggestions! I'll try to make a rear cargo rack blending designs from yours and the Bovington Panzer 3. BTW - did you use dyedcandle wick for your rope? It looks very authentic.
Old 09-29-2010, 01:33 AM
Wizzard033
Very nice weathering! Where can I get some weathering tips from? I plan to finish my Tiger I soon and I want to use a scheem i have found then use a wash and dry brushing over it is that the correct way to get the effects?
13./SS Pz. Rgt 1, July 1943, Operation Zitadelle
Old 09-29-2010, 05:38 AM
edoubleaz
edoubleaz's Avatar
Try our guide...
http://web.mac.com/ethandunsford/DAK...ING_GUIDE.html
Old 09-29-2010, 11:02 AM
Disposable Hero
Disposable Hero's Avatar
sweeeeet!
