Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
graphs 2s x 5000 lipo
Old 02-20-2011 | 01:27 PM
My Feedback: (325)
Default graphs 2s x 5000 lipo
As I get some hardcase packs (mostly cheap ones) I'll graph them here to compare them.
I was thinking these:
http://www.hobbyking.com/hobbycity/s...idProduct=9437
http://www.hobbyking.com/hobbycity/s...dProduct=14976
http://www.hobbyking.com/hobbycity/s...dProduct=14991
http://www.hobbypartz.com/83p-5000ma...4-30c-car.html
http://www.hobbypartz.com/83p-5000ma...4-20c-car.html
http://www.hobbypartz.com/77p-sl5000-2s1p-40c-2222.html
Old 02-20-2011 | 01:29 PM
My Feedback: (325)
Default RE: graphs 2s x 5000 lipo
ACQ 2sx5000 40C pack from hobbypartz http://www.hobbypartz.com/98p-40c-50...-hardcase.html for $35
I conclude after testing this pack that it will never make it at 40C without melting the cell tabs off. I prefer to get a hardcase pack without the pc board. I'd like the leads directly soldered to the tabs. Consider this a 25C pack with the cells at 140 deg F.
ID:	1567120   Click image for larger version
Old 03-27-2011 | 07:39 AM
My Feedback: (325)
Sky Lipos 40C 2sx5000
First PIC 5,10,20,50 amps Temp delta F 0,10,15,45
2nd PIC 100,120 amps Temp delta F 60,65
3rd PIC 150,200 amps Temp delta F 70,83
There was no apparent cell pressure even at the 200 amp test , but at the end was cut short because the + lead solder melted off. I can consider this a 30C pack and was much better than expected.
ID:	1584821   Click image for larger version
ID:	1584822   Click image for larger version
Old 05-01-2011 | 10:36 AM
My Feedback: (325)
Turnigy 30C 5.2 hardpack from HobbyKing $24 These are 2s2P packs
http://www.hobbyking.com/hobbyking/s...dProduct=14991 from USA.
First PIC 5,10,20,50 amps Temp delta F 0,20,31,46 or actual temp 60,80,91,106
Second Pic 10,20,50,60 Max 116 deg F
Third Pic 100, 120 amps Temps were 140 and 146
This is a pretty good pack for $24 and would be my pack of choice for Monster trucks that need to fit a hardcase standard sized pack. I consider it a 20C pack.
ID:	1602068   Click image for larger version
ID:	1602069   Click image for larger version
Old 05-01-2011 | 10:41 AM
My Feedback: (325)
Turnigy 20C 5.0 hardpack from HobbyKing $20
http://www.hobbyking.com/hobbyking/s...dProduct=14976 from USA
Current 5,10,20,50 Temp delta F 0,20,37,60 or actual temp 60,80,97,120
Second pic is 10,20,50,60 amps with 140 max temp. Call this a 10-12 C pack. For $20 a nice small lightweight package will do lots of single pack 1/10 scale stuff really well. Maybe even some dual pack mild monster trucks.
ID:	1602079   Click image for larger version
Old 05-01-2011 | 11:15 AM
My Feedback: (325)
HobbyKing B grade 20c 2sx5000 $10.47
http://www.hobbyking.com/hobbyking/s...dProduct=15485
Current 5,10,20,50 Temp delta F 16,25,42,70 or actual temp 76,85,102,130
Second pic is 10,20,50,60 amps with a max of 140 deg F. We better call this a 10-12 C pack.
ID:	1602099   Click image for larger version
Old 05-01-2011 | 11:26 AM
My Feedback: (325)
HobbyKing B grade 30c 2sx5000 hard pack $15
http://www.hobbyking.com/hobbyking/s...dProduct=15497
First Pic Current 5,10,20,50 Temp delta F 17,28,38,70 or actual temp 77,88,102,127
Second Pic 10,20,50,60 amps.
Cell tabs on this are about 140deg F when doing 50 amps and 200 deg F when doing 60 amps. The soft pack above is a better deal if you can fit it. This must be called a 10C pack.
ID:	1602107   Click image for larger version
Old 05-01-2011 | 11:35 AM
My Feedback: (325)
HobbyKing B grade 30c 2sx5.8 $16
http://www.hobbyking.com/hobbyking/s...dProduct=15504
First Pic is 5,10,20,50 amps Temp delta F 13,27,35,66 or actual temp 73,87,95,126
Second Pic is 60 and 100 amps (60 amps runs 136 degF) (100 amps is melting something inside so I quit)
This might be called a 12-15 Cpack.
ID:	1602110   Click image for larger version
Old 05-15-2011 | 04:03 PM
My Feedback: (325)
Compare (all these will fit a standard old e-maxx tray) 120 , 100 , 50 , 20 , 10 amps
Sky Lipo 40c softpack 2sx5000
ACQ 40c hardpack 2sx5000
Turnigy 30c Hardpack 2sx5.2
I'd buy the Turnigy or the Sky if I had to fit in old 6 cell trays. If soft pack then get the Sky. If hardpack then get the Turnigy.
ID:	1609130   Click image for larger version
ID:	1609131   Click image for larger version
ID:	1609132   Click image for larger version
ID:	1609133   Click image for larger version
