Maj. Woody's X-Treme Jets BAE Hawk 1/5.5
#509
My Feedback: (28)
Next up is to improve the flap linkages. The problem is that the flap servo cutout from the factory has the servo almost flush with the upper wing skin. This forces you to use a long servo arm or cut a longer channel in the skin for your push rod as it seeks a hole in the servo arm closer to the spline.
#511
My Feedback: (28)
I also decided to upgrade my flap servos. The 645MG have served me well in the past on flaps, but were not up to the task in this model. I installed Futaba 9155 digital s in their place. This is a 192 ounce servo. By raising the servo as I did , I was able to mount the push rod two holes closer in to the spline giving me a much better mechanical advantage over the previous setup.
#514
My Feedback: (28)
Well it was a very bad day at the field yesterday. It started out great. The Hawk looked just beautiful on the tarmac and in the air. I had two perfect flights with amazing landings. This jet just flies itself to the runway every time! On those flights I heard some very mild buzzing.I do not think it was control surface flutter, I think it was the gear doors that stay open but I will never know for sure. On the third flight, I was going through my normal aerobatic routine and the jet felt rock solid as usual. This was flight number 8 on the jet. I did a knife edge from right to left with the canopy facing me. Right rudder was used and the plane tracked in Knife edge like it was glued to a wall. I rolled out of the maneuver and immediately felt something was not right. The plane felt very odd to control. In fact it wanted to fly on its side! Turning was difficult. Very wide and lacking a solid groove through the turn. I managed to get her on the down wind and dropped the first notch of flaps and the gear. While looking for the switch to drop the last notch of flap (I just moved the flap control from the left slider switch to a 3 position switch on the transmitter), I took my eye off the jet for a second. In that time, it rolled inverted. When I put my eye back on the jet, I was disorientated and quickly drove the jet into the woods below. Pilot error for taking my eye off the jet. The jet needed constant input because of the odd control situation and would not fly hands off. I feel I had things somewhat under control and could have landed it if I had not taken my eye off the jet. What I found out back home when I plugged things back in and turned on the radio is that the rudder was locked to the full right position. Why it did this I do not know. The fin was not damaged in the crash and the rudder and linkage were intact. The rudder was moving freely through its range of motion but when I turned on the system, went hard right. I have a lot going through my mind right now having just returned to turbines after leaving them due to the frustration I was having with them a year and a half ago. At over $8500 per jet (remember I bought bran new everything for both the F-4 and Hawk) I just cant afford to replace it. In fact the Hawk still isn't paid for and now its gone. My F-4 might be up for sale. I need a day or two to completely think about it.
#515
My Feedback: (25)
Damn Dom, that just plain sucks. Wish I had some encouraging words, but I am at a loss. Was looking forward to seeing the Hawk at Ky Jets. Your thought and the extra attention to detail in putting these models together is over the top, and then have something like this happen surely makes you want to backup and re-evaluate. Sorry for the loss.
#516
My Feedback: (44)
Dom, I am very very sorry for the loss of your jet, when I received the call yesterday I actually got a stomach ache!
You have put so must time and effort into these jet to have something like this happen, it is unmanageable.
What model number of servo was it?
#517
My Feedback: (28)
OMG Rich. I just came up here to post my findings and you guessed it. The Dubro Super strength servo arms slipped on the spline! I checked my 425oz elevator servo and it is slipping there too. This is what led to my crash. Ultimately the crash was my fault but this was the major contributing factor.
#518
ORIGINAL: MaJ. Woody
#519
My Feedback: (28)
During the knife edge, the servo arm slipped on the spline. When I went to neutral, the rudder was now offset giving me that yaw and making the jet difficult to turn and keep level.
My F-4 is setup the same way! If I sell it, the new owner must switch to aluminum arms. If I keep it it will not fly with anything less than aluminum.
Wow, I have used these arms for years in all my jets...hundreds of flights between them. Never an issue. Blows my mind.
#522
Oh no Dom. I'm so sorry. Give yourself some time to think before you sell stuff. Really sorry to hear this. Hang in there.
Scott
Scott
#523
My Feedback: (28)
ORIGINAL: RCISFUN
Dom,
I know you fly both Futaba and Hi-Tec servos, is there a chance you used the wrong arm on the servo?
They are very different splines....[&:]
Dom,
#524
My Feedback: (28)
Thanks for the kind words.
Just about everything is reusable so far. All my equipment stayed on the boards.....secured. The trees...ripping the wings off absorbed a lot of the force. The turbine is messed up however. I am packing it now to send it in for evaluation. Whether this can be fixed may be the deciding factor for me not selling my stuff.
Nice job, have fun this week!
