RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
Kenworth wrecker
Old 01-24-2012 | 03:04 PM
Default Kenworth wrecker
This is a build loosely based on a '42 Kenworth wrecker. I'm using a worminator chassis with outcry bushless motor and ESC. Tamiya King hauler cab and the rest is
scratch built including the boom and trunion/winch base. I've made much more progerss since this pic, but need to download and size them. More to come soon.
Old 01-24-2012 | 03:08 PM
Default RE: Kenworth wrecker
Nice work....
Old 01-24-2012 | 05:03 PM
The Mad Modder's Avatar
Going for the military version?
Old 01-24-2012 | 06:45 PM
yup, based off that, but crawler recovery version.
Old 01-25-2012 | 02:11 PM
i am absolutley baffled by some of the projects i see on here. whenever i see these types of projects i cant help but ask myself, why arent these guys in buisness making these for the rest of us lol. nice work man. really, that is impressive
Old 01-25-2012 | 02:20 PM
Thanks Diabolic, wait till I get some more pics up.  The boom and winch setup is pretty cool!
Old 01-25-2012 | 02:28 PM
SyCo_VeNoM's Avatar
ORIGINAL: diabolic-mind
easy once you start doing it for money its no longer a hobby, and starts to become more of a hassle that you start to hate.
Or at least that's how it was when I made one of my old hobbies into work many years ago.
To the OP looks nice
Old 01-25-2012 | 03:56 PM
looking good man. waiting to see the rest of the build
Old 01-26-2012 | 10:47 AM
Update on the wrecker. These pics are of the the winch/trunion deck, electronics deck which will be hidden under the cab, and the winch's and boom with all lines installed.
ID:	1719317   Click image for larger version
ID:	1719318   Click image for larger version
ID:	1719319   Click image for larger version
Old 01-27-2012 | 07:28 AM
this thing is going to be badass when its finished, i can already tell!
Old 01-31-2012 | 06:21 AM
Couple more pics. In These you can see the tank turrrettraverse gearbox and turret ring used to rotate the boom. Also I had to make some new shock springs to hold up the weight of all the
new aluminum and lifting gear in addition to any load being lifted.
ID:	1721480   Click image for larger version
ID:	1721481   Click image for larger version
ID:	1721482   Click image for larger version
Old 02-11-2012 | 01:20 PM
Some more progress. Rear deck and tool box to hide winch ESC's along with spare tire.
ID:	1725751   Click image for larger version
ID:	1725752   Click image for larger version
ID:	1725753   Click image for larger version
ID:	1725754   Click image for larger version
Old 04-04-2012 | 03:17 PM
Just bought a new house, so the build on the wrecker will be on hold over the summer till I get moved and settled in.
Old 04-04-2012 | 08:26 PM
narwalrus's Avatar
http://www.rigsofrods.com/repository/view/3493
I've been using this truck in Rigs of Rods... check out the 3D rotation <br type="_moz"/>
Old 06-20-2017 | 11:33 AM
Got bored of this sucker staring at me from the shelf so I slapped on paint and some details of the cab. Looks cool but pretty much non practical as most r/c's don't have a neutral. Can still lift or pull a crawler out of trouble though. Light bar is pretty nice, only around $20 shipped and is plug and play to an open channel on your rx for on/off and switching between 4 sequences. Have mine on the gear channel.
https://www.youtube.com/watch?v=anVt...ature=youtu.be
Old 06-20-2017 | 04:16 PM
Mike Flea's Avatar
Very nice, Benny. Where did you get the gearbox that rotates the boom?
Old 06-20-2017 | 04:48 PM
Had an extra laying around from a 1/16 Heng long tank.
Taigen Tanks Turret Rotation Unit (TAG120619) | eBay
And the ring.
Large HengLong 1/16 Tank Turret Rotation Steering Gear pinion 360 Degree | eBay
Old 06-21-2017 | 05:22 PM
Mike Flea's Avatar
Thanks, I may be able to use that for a crane I'm building for my 1/20 train layout
Old 06-21-2017 | 06:13 PM
RustedRC's Avatar
It's a great looking truck Benny. awesome lights. they fit the truck well.
Old 06-22-2017 | 05:26 AM
Thanks fella's. Working on some more detail parts to throw in the bed. Will put up some pics when they are done.
Old 06-22-2017 | 03:30 PM
Spare tire/wheel, engineering tools, tow cables and shackles added.
ID:	2221220   Click image for larger version
Old 06-22-2017 | 04:12 PM
Mike Flea's Avatar
Looks good, you should make a tool box to cover the motor that runs the boom. It'll hide the power wires and protect the motor from dust and debris.
Old 06-22-2017 | 04:23 PM
Yea, was thinking about that. Quick box out of styrene should do it, only issue may be the gearbox is spring loaded to make up for the not so perfect circle of aluminum I got to make the winch base. Suppose I could just double side tape it to the top of the gearbox so it can travel with it.
Old 07-06-2017 | 04:05 PM
Couple more details. Mobile welding unit, cutting torch tanks and brackets to hold some more chain. Just about wraps it up, not going to crazy on the detailing on this build.
ID:	2223256   Click image for larger version
Old 07-07-2017 | 01:39 PM
Mike Flea's Avatar
Looks good!
