Site Problems fixed?
Things may be looking up:
http://www.rcuniverse.com/forum/m_10...m.htm#10989045
The site seems to be running well again
RE: Site Problems fixed?
Spoke too soon I guess. Just got this as I tried to go back home after posting. Never saw this one before:
Microsoft OLE DB Provider for SQL Server error '80004005'
Transaction (Process ID 216) was deadlocked on lock resources with another process and has been chosen as the deadlock victim. Rerun the transaction.
/forum/js/globalSessionFunction.asp, line 41
The site was running fine eariler today the two times I was on here however just now when I clicked on this thread It locked up and I had sign off and back on again
my web browser to get back on to RCU.
ORIGINAL: RAMFlyer
Nope, STILL not any better for me. And that is with either Chrome or IE 8.... Still S%U%C%K%S!!!! OFF TO RCG
Well , , Good luck with that ......... I'll take slow and buggy over Demonically Moderated ANY day ....... [:@]
My Feedback: (65)
Nope; three "500 system errors" and two "cannot connect with that website" before getting through. And I have found RCG to be much more lightly moderated than RCU...
ORIGINAL: RAMFlyer
Nope; three ''500 system errors'' and two ''cannot connect with that website'' before getting through. And I have found RCG to be much more lightly moderated than RCU...
RCU does seem to be working better for me.
Grrrrr, I'm still getting this,,,
We are sorry...
You are seeing this message because of one of the following reasons:
Your session timed out.
The server was restarted before you made a HTTP POST (posting a message, registering an account, login, etc.)
Problem #1:
You probably spent too much time and your session timed out. This is, however, rarely the cause of the problem because we implemented a session keep-alive mechanism to prevent this issue from happening. However, the server itself could have experienced some problems that prevented this mechanism to work as it should, and therefore we cannot completely rule out the possibility of this either.
You need to make sure your browser has cookies enabled. See below for instructions:
Netscape Communicator 4+:
Select "Edit" from the browser Menu bar
Select "Preferences"
Double click on "Advanced"
Verify that "Accept only cookies that get sent back to the originating server" is selected
Select the "OK" button
Microsoft Internet Explorer 4+:
Select "View" from the browser Menu bar
Select "Internet Options"
Select "Security" tab
Select "Custom (for expert users)" security level and select the "Settings" button
Locate "Cookies" and verify that "Allow per-session cookies (not stored)" is enabled
Select the "OK" button on the "Security" window
Select the "OK" button on the "Internet Options" window
If you already have cookies enabled and still experienced the problem, see problem #2 below for other possible causes.
Problem #2:
Your server experienced problems and was forced to restart. Restarting a server will erase all session data and our protective mechansim had no choice but to drop your HTTP POST because we had no way to identify you without valid session data.
Many forum administrators host their forums on shared servers, on which could have more than 200 sites hosted together. Sometimes the server has to be restarted because some badly written programs on other sites may drain the CPU/RAM and cause the IIS to restart itself. This is unfortunately an inevitable situation that many site administrators and its users have to face from time to time.
Technical Information
For more information, please contact forum admin.
BV
We are sorry...
Problem #1:
Problem #2:
BV
My Feedback: (65)
Sorry to hear you were treated poorly at the other site! If I came across as rude, didn't mean it that way. I was just trying to report that RCU was, at that time, still a disappointment for me. HOWEVER, I must admit that the past two days things are really looking up. Except for problems loading a couple of sale items in the Market, this site has been moving right along...
