Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
steps boat that I design in 2009
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 04-22-2012, 11:42 PM
c.k.y.
c.k.y.'s Avatar
Default steps boat that I design in 2009
First, I use translator to understand English
But I like RC boat very much .....
I have begun to play contro lline airplaneboat vehicle from 1972' various model( however most like is model boat)
Model boat match is to begin from 1974'
Have also attended world championrace in the year of 1990/1992/1994/1996'
Do a 1.38M of long boats in 2009 with wooden system ,Can use 27-35cc gasoline engine .
From long match experience, know that actual boat and model boat are not designed together (So, this is just significant test and test !! )
Hope that everybody has the friend a discussion of this kind of boat
ID:	1753933   Click image for larger version
ID:	1753934   Click image for larger version
ID:	1753935   Click image for larger version
ID:	1753936   Click image for larger version
ID:	1753937   Click image for larger version
ID:	1753938   Click image for larger version
ID:	1753939   Click image for larger version
ID:	1753941   Click image for larger version
ID:	1753942   Click image for larger version
ID:	1753943   Click image for larger version
Old 04-23-2012, 12:11 AM
c.k.y.
c.k.y.'s Avatar
Default RE: steps boat that I design in 2009
Boat bottom share .
1)Ladder step length proportion
2)Ladder step is high
3)Use directly guides or is the drive of flexible shaft
Hope that much some friend attends opinion
ID:	1753945   Click image for larger version
ID:	1753946   Click image for larger version
Old 04-23-2012, 09:19 PM
c.k.y.
c.k.y.'s Avatar
This wooden boat has been tested in 2010 , At that time, use the new 26cc of a original factory for test ,
The revolution of brand-new Engine can go to 14,560 (The same day just this running-in motivation )
Under no big wave run do not feel that is rapid , However run together with the boat of 2 friends will not also feel to slow very much !!
(The pitiful new engine of 26cc will guide the boat of this 1.38M )
ID:	1754204   Click image for larger version
ID:	1754205   Click image for larger version
ID:	1754206   Click image for larger version
ID:	1754207   Click image for larger version
ID:	1754208   Click image for larger version
ID:	1754209   Click image for larger version
Old 04-23-2012, 09:28 PM
c.k.y.
c.k.y.'s Avatar
Hope friends can see Chinese Hong Kong regard frequency website
I in Hong Kong this Time is afternoon 13:50
First regard frequency to run boat will test boat follow front boat run change !
player.56.com/v_NDUxODgxNDU.swf
player.56.com/v_NDUxODg1MTk.swf
player.56.com/v_NDUxODg1NTc.swf
ID:	1754211   Click image for larger version
Old 04-23-2012, 11:08 PM
w3bby
Nice, neat build and innovative design.
Looks like you have a nice place to run
How does the wooden bottom hold up with the direct mounted engine?
Old 04-23-2012, 11:28 PM
c.k.y.
c.k.y.'s Avatar
ORIGINAL: w3bby
Hi Ian
I in department adds completely cloth, under engine have three-layer to consolidate
Test is completed can use hot wind gun is easy to take apart !!
cky
Old 04-23-2012, 11:44 PM
c.k.y.
c.k.y.'s Avatar
Boat surface system does !
Design one gives 35cc and one 26cc
ID:	1754245   Click image for larger version
ID:	1754246   Click image for larger version
ID:	1754247   Click image for larger version
ID:	1754248   Click image for larger version
ID:	1754249   Click image for larger version
ID:	1754250   Click image for larger version
ID:	1754251   Click image for larger version
ID:	1754253   Click image for larger version
ID:	1754254   Click image for larger version
ID:	1754255   Click image for larger version
Old 04-23-2012, 11:56 PM
c.k.y.
c.k.y.'s Avatar
The time that has free time in this year will use a 35cc to test....(See whether can exceed 100 K / M )
But first to do mould use the boat body of epoxy resin !!
I am waiting to take over CMB-27cc straight emission engin to comeeing
ID:	1754257   Click image for larger version
ID:	1754258   Click image for larger version
ID:	1754259   Click image for larger version
Old 04-28-2012, 07:33 AM
c.k.y.
c.k.y.'s Avatar
Gray paint spray on the bottom.....Smooth color...... Repeat
again repeat
ID:	1755956   Click image for larger version
ID:	1755957   Click image for larger version
ID:	1755958   Click image for larger version
ID:	1755959   Click image for larger version
ID:	1755960   Click image for larger version
ID:	1755961   Click image for larger version
Old 05-23-2012, 10:09 AM
c.k.y.
c.k.y.'s Avatar
Today receives new CMB-27cc engine
Put in a DF-49 " boat, feeling boat is too little ....
ID:	1765208   Click image for larger version
Old 05-23-2012, 03:57 PM
glennb2006
You must be one of the first people in Hong Kong to have one, let us know how it runs. I have seen one and it looks like a "proper" race engine. Have you modified yours yet or are you going to run it stock?
Glenn
Old 05-23-2012, 09:13 PM
c.k.y.
c.k.y.'s Avatar
ORIGINAL: glennb2006
Glenn
Hi Glenn
I will attend the German world championships of 2012 ( FSR-O-27 Class )
I first meeting Engine running-in is good , Make modification again ...( But I can ask your British famous general Ian Folkson for advice ).
Because the propeller diameter of FSR-O is compared , I must want to notice torque !!
I feel that this engine propeller scope is been by 65 - 67 mm diameter ......But must is increasing Picth test !
I hope that this Step boat can be completed July ago ! (It has , is good to fight wave and rapid speed )
CKY
Old 05-24-2012, 02:26 AM
w3bby
ORIGINAL: c.k.y.
Hi Ian
You were answering Glenn but I know all us English look alike Good to know you will be attending the Naviga Championships, you will meet some tough competition.... I may drive down for the finals but it will be the FSR-V classes if at all. Shame with the split championship as in Norway I was able to catch all classes over a few days.
The CMB certainly seems to have the makings of a good motor, there is a choice coming with the BZM and (so I have heard) Mathe joining the ranks of the 27cc. Just a pity that the cost side of the class will be high.
Old 05-24-2012, 04:54 PM
specialk1
specialk1's Avatar
ORIGINAL: c.k.y.
First, I use translator to understand English [img][/img]
I have begun to play contro lline airplane boat vehicle from 1972' various model( however most like is model boat)
Have also attended world champion race in the year of 1990/1992/1994/1996'
I love looking at your pictures , keep up the good work
Old 05-24-2012, 10:39 PM
martno1fan
martno1fan's Avatar
Interesting design,can you explain to me why the step is so far forward on the hull?,sureley once the boats running its not even in contact with the water so has no effect whatsoever?.
Mart
Old 05-25-2012, 11:39 AM
c.k.y.
c.k.y.'s Avatar
ORIGINAL: w3bby
ORIGINAL: c.k.y.
Hi Ian
Hi Ian
I also have a Mathe 35c.c.c,( Installed in a DF-53 "boat )
A long time ago I was like racers of FSR-V...But have a different problem because the club....So !!!!
I have some old photos in the world championship ! Hope Former friends did not forget me !!
CKY
ID:	1765756   Click image for larger version
ID:	1765757   Click image for larger version
ID:	1765758   Click image for larger version
ID:	1765759   Click image for larger version
ID:	1765760   Click image for larger version
ID:	1765761   Click image for larger version
ID:	1765762   Click image for larger version
Old 05-25-2012, 11:57 AM
c.k.y.
c.k.y.'s Avatar
ORIGINAL: specialk1
ORIGINAL: c.k.y.
Hi specialk1
I am now 52-year-old elderly !!
Production of any model will be careful to avoid error ,
Old 05-25-2012, 12:19 PM
c.k.y.
c.k.y.'s Avatar
ORIGINAL: martno1fan
Mart
Hi Mart
I use translator to understand English ,I hope you can understand what I mean !!
The same length of the hull, but Step distance tail relatively far will stabilize ....(.Run big waves are stable in the same length,For the FSR-O... )
The boat's center of gravity,(CG )can be compared to previous.... (.Decreases by the updraft impact )
CKY
Old 05-25-2012, 12:54 PM
advanced builder
advanced builder's Avatar
Looking good CKY Thanks for the post. your darn good builder.
Old 05-25-2012, 04:30 PM
glennb2006
Picture four of Ian Folkson looking very young!!
Glenn
Old 05-26-2012, 05:24 PM
HendricX
HendricX's Avatar
Yup ... and Aad Bervoets had blond hair ... ha ha
So ... must be years ago ;-)
Old 05-27-2012, 05:53 AM
c.k.y.
c.k.y.'s Avatar
ORIGINAL: HendricX
HIHendricX
In Slovenia in 1996, I also have long black hair, ha ha
You will go to the German race?
CKY
Old 05-27-2012, 01:49 PM
HendricX
HendricX's Avatar
ORIGINAL: c.k.y.
I also have long black hair , ha ha
You will go to the German race ?
For me that was 20 years ago ... hair-color ... ha ha
I'll be in Germany , as technician for my apprentice Kees Zwartbol , and to watch.
As Peter Inglof and I are the only white haired/bearded persons overthere , I'm easy to find. :-)
Old 05-27-2012, 03:46 PM
glennb2006
ORIGINAL: HendricX
ORIGINAL: c.k.y.
Unless Dave Marles grows a beard Henk!!
Glenn
Old 05-28-2012, 10:38 PM
c.k.y.
c.k.y.'s Avatar
ORIGINAL: HendricX
ORIGINAL: c.k.y.
Glenn
Hi Glenn
I retrieve the photos of the 1990 World Championships in Austria
Dave Marles of 6.5cc boat when the propeller is broken at the last minute , I watch the scene
In addition there are some in the 1992 Swedish
CKY
ID:	1766875   Click image for larger version
ID:	1766876   Click image for larger version
ID:	1766877   Click image for larger version
ID:	1766878   Click image for larger version
ID:	1766879   Click image for larger version
ID:	1766880   Click image for larger version
ID:	1766881   Click image for larger version
