SMOKE OIL MIX?
Hello guys.
installing a smoke system(sullivan skywriter).
Whats the best home brew mix for the best smoke?
Also, do you power the pump independant from the reciever or not?
Thanks mario.
Thanks mario.
My Feedback: (16)
Hydraulic oil from Walmart works pretty good
Canopus 13 or Corvus oil from Texaco works well also (sometimes spelled "Corvis")
<font size="5"><font color="#FFFF00">Best</font></font>
Aeroshell Smoke Oil
Texaco Canopus 13 or 19
Texaco Corvis 13
<font size="5"><font color="#FFFF00">Good</font></font>
Exxon Telura 613
Petro Blend Smoke Oil
Shell Carnea 10 or 22
Shell / Exxon Carnea E-15 (10 weight)
Shell Vitrea 13 or 22
Super-Dri</p>
<font size="5"><font color="#FFFF00">Acceptable</font></font>
American Rayco 460
BP - Enerpar 20 (viscosity rating of 10)
Citgo Sentry 15
Conoco / Phillips "Industrial Oil" (10 weight)
Conoco / Phillips 80N and 70N
Meadows Concrete Form Oil (oil base), (stinks but it works)
Unocal 76 - 76 Klondyke</p>
NC
The Skywriter is an awesome pump. Run it on a seperate 6volt battery. Superdri is the best oil out on the market, but if you want to mix your own, its 33% deisel fuel, 33% kerosene, and 33% automatic transmission fluid. Good-luck.
MB, CANADA
For little to no clean up use super dri and if you have oil residue under your plane turn down your smoke pump. Set up your pump and pump water thru it for 15 minutes to wear in the gears, can make a big difference.
Im cheap, I just use deisel fuel.
It cheap and when im at the gas station makeing my 2 stroke, Ijust fill up my little gal smoke jug. I have also added a splash of 2 stroke oil in the deisel wich gives a little better smoke.
Just rember don't turn your smoke on at low RPM, I use my smoke to shut off my motor after Iland,
I love turn the smoke on after I land, but never while while landing as it can couse your motor to shut off.
I power mine with a cheap HK 2s 800mah lipo.
Also remember you will use smoke faster than your main fuel.
You will want to be careful with some of these home brews because they can damage film type coverings and even paint finishes. I am using a 50/50 mix of kerosene and mineral oil, which I get at my local tractor supply store. kero is $4 gal and the mineral is $18 so for $22 I get 2 gal of oil and my 20cc engine will use 12 oz in about 45 sec of continues smoke. I found that if your volume is turned up to high you will cool the muffler off too much and waste alot and get less smoke.I was atan event this fall with full scale planes and one of the pilots asked what I was using because I smoked better than his full size. Lots of choices this is just one, but it smells alot less than some others like diesel, and wont hurt the finish like form oil and brake fluid. I also use a separate lipo 1500 mah 7.2v and my pump is Sonic Tronics Good luck and have fun with it.
You realise that Diesel fumes and exhaust fume, untreated via catalyst has been raised to the level of carcinogen by the World Health Organisation...
So has going out in the bright sunshine without sunscreen, so your point is what?<div>
</div><div>
</div><div>
</div><div>
</div><div>
</div><div>
</div><div>Speaking of Smoke systems, what is a decent inexpensive system for a Magnum 91 FS in A CG Chipmunk? </div>
</div><div>
</div><div>
</div><div>
</div><div>
</div><div></div><div>Speaking of Smoke systems, what is a decent inexpensive system for a Magnum 91 FS in A CG Chipmunk? </div>
