Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Taco .25 plans
Old 09-22-2009 | 06:48 AM
  #526
Default RE: Taco .25 plans
Hi! what engine four strokes for this plane? a os fs30? fs40? Thanzs!
and, the process of building the landin gear?
Old 09-29-2009 | 12:13 PM
  #527
I need help for building the landing gear .
Old 10-14-2009 | 02:12 PM
  #528
ORIGINAL: PaulSwany
I finally finished the Taco plans... Here they are in both dxf format and AutoCad 2000 format...
Download Plans
It's a .25 size fun fly that flys really well with a BB .25 engine. It was originally designed by Troy Smith (aka MiL) I did a little redesign with a tripple tappered wing and modified tail surfaces. I have a Irvine .25 in mine. Here's are rest of the specs:
Wing area: 450 sq in.
Weight: 2.25 - 2.5 lbs.
Wing Load: 12.8 oz / sq ft.
More Taco Pictures
In that scale print this plane pliss taco 25
Old 10-14-2009 | 02:15 PM
  #529
Somebody knows to that scale can print this plane pliss
Old 10-14-2009 | 02:41 PM
  #530
direct impresion .
Old 10-22-2009 | 10:29 PM
  #531
to print this map scale 1:1 or 1:2 thanks
Old 10-22-2009 | 10:43 PM
  #532
ORIGINAL: top242
direct impresion .
I'm sorry but I find the print is 1:1 scale, or should I give instructions to the person doing the printing through
Old 10-23-2009 | 03:14 AM
  #533
1:1
Old 10-23-2009 | 10:09 AM
  #534
ok 1:1
Old 10-30-2009 | 06:56 AM
  #535
i need the angles of engine! thanzs!
Old 11-01-2009 | 05:52 PM
  #536
degrees of engine? 0º 0º? or 1º down 1º rigth? other´s?
Old 11-02-2009 | 11:30 AM
  #537
PaulSwany's Avatar
My Feedback: (45)
2º - 3º of right thrust. 0º on everything else.
Old 11-02-2009 | 03:21 PM
  #538
Very thanzs!
Old 11-13-2009 | 09:56 PM
  #539
ORIGINAL: somegeek
Ready for the maiden flight...
A lot heavier than I wanted... 2lb 11 oz... tried to save weight here and there. Imagine a lighter engine woulda made a difference. This GMS .32 is 12.65oz. Hoping a 10x3 will pull it around okay.
The carbon fiber ribbon I put on the spruce member down the middle of my fuse just didn't cut it so I added a piece of Carbon Fiber Strip bolted in place with 2-56 hardware. Very rigid tail now.
Now I just need a good day at the field.
somegeek
Nice plane, Picked 1 up at a swap meet for 60.0. Installed magnum .25. really digging this plane. Only flew it once so for. Had a dead stick down wind and broke prop. Cannot wait to fly it somw more. glad I found this forum.
but whatever
Old 05-06-2010 | 10:37 AM
  #540
Hi! what ist the size of the reservoir combustible? 4 oz, or 6oz, Thanzs!
Old 05-06-2010 | 11:04 AM
  #541
Goinstraightup's Avatar
My Feedback: (26)
On this size plane 4oz.
Old 05-06-2010 | 11:31 AM
  #542
Ok, very thanzs!
Old 05-06-2010 | 08:07 PM
  #543
PaulSwany's Avatar
My Feedback: (45)
4 oz. Hayes worked perfect for me.
Old 07-14-2010 | 10:44 AM
  #544
Hi Again! i have fly the taco! ist prety plane! . But i need help to position of the gas servo. Have you pictures? The travel servo ist no god for my. Ist plenty to te middle movement of the stick. Thanzs again!
Old 07-14-2010 | 11:55 AM
  #545
My Feedback: (26)
Here's how I did my Mojo 25. I replied to your PM with details, I'm glad this file posted here, it was too big for a PM.
Old 07-14-2010 | 02:37 PM
  #546
Thanzs!
Old 06-11-2022 | 01:22 PM
  #547
Download Plans
More Taco Pictures
In the spirit of preservation, plans are available here; Wayback Machine
More Taco Pictures here: Taco .25 Finished
