os bgx prop
os bgx prop
HELLO GUYS!
CAN THIS ENGINE SWING A 20/10 PROP?
WHICH IS THE BEST FUEL FOR IT?
I´D LIKE TO USE 0% NITRO.IS IT WORKS?
PLEASE TELL ME ABOUT YOUR EXPERIENCE WITH BGX
REGARDS
MARCIO
REGARDS
MARCIO
RE: os bgx prop
What kind of plane and flying are you going to do. This would yield better info.
ORIGINAL: marciouca
HELLO GUYS!
REGARDS
MARCIO
HELLO GUYS!
REGARDS
MARCIO
My Feedback: (227)
CA
RE: os bgx prop
Im using a 20x8 carbon fiber prop on a Great Planes Patty Wagstaff ARF. The engine is pumped. I have experimented with different fuel mixes and found the best mixture to be 5-7% nitro with the recommended 18% oil. Less nitro will result in a little bigger "flat spot". Much more than 7% and the engine started to run warm in my application. I tried 15% in the very beginnig and could not get the engine to run rich at top end.
My plane weighs 15lb wet. Although it will not rocket out of a hover it has plenty of power. The carbon fiber prop yeilded 400rpm more than the Top Flite wood prop. The engine turns 7400-7600 rpm static on a good day. If you can somehow get 8000 RPM with a 20x8 you will have all the power you could ever want in a 15lb plane.
I love this engine. The first start of the day is a little difficult only because you are guessing on the ammount of prime. After the first start the engine fires up with one BACKWARDS flip of the prop. It quit on me one time and that was because the Muffler was lying in the cowling.
I piped up here only because I spent quite a bit of time dialing this engine in and it has paid off. I hope you find the info useful
