Air Hogs Aero Ace!
#2851
My channel C (Red/Black) Aero Ace has has been one of the most fun 'toys' I've ever had.
Unfortunately the charging function has stopped working. I used to have to wiggle the connector and toggle the trasnmitter on and off to get the green light to come on, but now it refuses to do so.
I have taken the transmitter apart to check the conections and they look ok.
The plane charges fine with my channel B (Green/Yellow) transmitter.
I think I may take it back to Toys R Us and try to find a replacement at KB Toys.
#2852
Have you tried fresh batteries in the Tx yet? The charging circuit is usually the first thing to get blamed and the last thing to cause the problem. Worn batteries is usually the culprit.
#2853
I might have found some replacement props for the AA.
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGWM1&P=7]props[/link]
They fit the Micro Ultrix Bipe which has a link just below the props.
Also, anyone know about these other props?
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHHV4&P=7]GWS props[/link]
#2854
NY
ORIGINAL: FlyinLo
Try NEW batteries in the TX first.
Tom
#2855
CA
I also beleive in trying out new batteris first. You should still ge a charge from batteries worn down to 1v each. That said, I have burned out a couple of chargers. Not the charging circuit but the connector itself. I think it's the connector anyway. Tim
#2856
I have a couple of those orange props. I was using them for a direct drive tail system on one of my helis.
I've got a couple videos that I'll be posting. One is done. It's a short one with one of my Bipes taking off in the driveway. It may take a few minutes to show up.
[link=http://www.youtube.com/watch?v=8jGwobpjy94]http://www.youtube.com/watch?v=8jGwobpjy94[/link]
#2857
ORIGINAL: FERNDALE AIR FORCE
... You should still ge a charge from batteries worn down to 1v each. ...
#2858
ORIGINAL: GTX SlotCar
Once I posted a link and all that came up was the main page.
Your link shows the same stuff that was up there when I opened the link
for novielo's actuator a days ago. Guess you gotta wait.......
oh... did you try those orange props on the stock AA motors?
Ha! After punching it up a few times I got it.
Never seen one scoot around like that- who needs wheels?
#2859
GTX, Tommyr, Ferndale,
The batteries were about a week old but I swapped them out anyways per your suggestions.
Now it works intermittently again. I need to move the plug in and out multiple times to get the green light.
I put the week old batteries in the B channel transmitter and I get green with both planes.
So, the batteries do contribute to the problem but there is definetely a connection issue with transmitter 'C'
I like the Red/Black color scheme much better tan the Green/Yellow but I think I may have to return it.
On another note: I usually keep the altitude below the roof of the house since I got stuck there the first night I flew. Today I decided to see how high this thing could actually get. I was very impressed. Critical altitude seems to be at least 200-300' (this was on a full charge).
I wish I had a camera small enough to take pictures with this thing. It's been a while since I buzzed our house in a cessna.
#2860
CA
flyinlo, if it is a connector you could try to close it back down with a pick tool. Or you could try some connection grease. I have to admit to an excess of spare controllers. I don't bother to fix my charge bases, I just grab another tx. Tim
#2862
hey guys, just ordered a bunch of aero soarers for my shop, just wondering if the X-Twin lipos work with it? If so Il put an option so when you click to buy it will ask you you want it with a lipo. thanks
#2863
CA
SAma, what the ---- is an aero soarer? Is it something I need to look for? Is it a silverlit product? I assume it flies. More info please. Tim
#2864
Its a tru RTF living room flyer that is only 3grams problem is it only flys for 30 or so more seconds and chrages in 40 seonds more info here, http://toyeast.com/v3/pdtdetail.asp?pdt_id=A02103301
#2871
ORIGINAL: Neurotex
...oh... did you try those orange props on the stock AA motors?
LOL. It's got wheels, man
No, I never tried them on an AA. They're at work right now, so I can't compare them to anything. I think they're larger than the E-chargers blades, though. I have a ton of E-chargers that I haven't even taken out of the package. They're the ones that came free with the older AA's.
#2872
Hey 13BT I can send you a free sample of the AeroSoarer since you live in perth, but there are a few conditions. 1 you can have it for one week, 2 try not to damage it, i can understand an accident but dont go ripping it apart 2 You can write a review if you like it. I will pay postage to you and you pay postage to me or we can arrange a pickup or some thing. Hope you agree.
Patrick
Patrick
#2873
NY
ORIGINAL: sama
That's kind of neat! But the music they play in the video is murder on my ears!
Tom
#2874
Them props from GWS are larger than the stock AA'a at 2.5" but smaller than
the EZ Charger props. They might work well on the N20 motors without gears.
Haven't found any use for those EZ props- might try cutting them down.
FlyinLo, I've had this problem since day one trying to get that green light to
stay on with the first plug in. Usually after several attempts it stays on. Or, run the
plane a few seconds and then try it.
I believe, since the electronics are very cheap, that the charger is getting the
command that the lipo is fully charged even though it's not. It's getting a plug
in spike and the safety shut off, which prevents it from over charging, shuts it
down. That's my guess any way.
#2875
hey sama, how much is it in case i decide to buy it? Can you also do the same for the tiny heli? I live in South Perth and sometimes fly in the park nearby the river. take the road past Bunnings and Hungry Jacks and theres a carpark right down the end. Im there sunday mornings but let me know first if youre going to be there.
