Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
 Fastest gas RTR or almost RTR kit >
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 10-09-2005 | 12:03 PM
JPriami's Avatar
My Feedback: (21)
Default Fastest gas RTR or almost RTR kit
What’s one of the fastest RTR’s or kits that are pretty much RTR with some assembly required? I don’t want to spend over $1,400 but if I could keep it at or below $1000 it would be great. How fast? What brand? What model? Where to buy? How much?
Old 10-09-2005 | 07:36 PM
Default RE: Fastest gas RTR or almost RTR kit
Aeromarine builds a great RTR Donzi or their new XXX boat, for $1,400. MY Donzi was well worth the money, and does in the high 40's stock. My new XXX should be here this week, I will post the performance numbers once I get to run the boat.
Old 10-09-2005 | 10:12 PM
The XXX is rtr?
Old 10-09-2005 | 10:19 PM
JPriami's Avatar
My Feedback: (21)
It doesn’t have to be exactly an RTR. If it comes as a kit with everything included or comes with all the hardware & I have to buy an engine & radio. That’s fine.
Yeah that XxX looks pretty neat. I am also looking at the Avenger pro 44" And the Manta Ray from warehouse hobbies. I just wish I could find more out on the Zenoah engines. Are some stock & some modified? Wheres the best place to get the modified ones if so? Is the G26 a good motor or is there something better for the same price range?
Old 10-12-2005 | 09:23 PM
Fast rat porting, CC racing engines, and the Black widow kit from BH Hanson are all very good ways to modify the Zenoah.
Old 10-12-2005 | 09:48 PM
My Feedback: (13)
I highly reccomend CC Racing for your mod work they offer engines or you can send them one of your own and they will modify it for you I have one of there pro mod g 26's in my magnum 57 and it will run 50 plus mph thats a 57 inch boat remember
Old 10-13-2005 | 05:55 AM
under $1000 wharehouse hobbies super g pretty fast stock can be upgraded with the cash saved. HOW FAST DO YOU WANT TO GO????
Old 10-13-2005 | 10:54 PM
What would take a Magnum 57 to 70MPH+? Is it big enough to house twins?
Old 10-14-2005 | 08:15 AM
I have a Donzi 49 rtr that will be for sale. I am making maden voyage today to set it up. The hull is all white, zenoah 260 power and Aeromarine hardware. The hull is an Aeromarine and not a splashed look-a-like. AM price is $1,455.00 rtr. Will sell for much less without radio.
Old 10-14-2005 | 09:24 AM
HOw much would you sell for or trade for?
Old 10-14-2005 | 10:49 AM
Justaddwata's Avatar
For a Magnum 57 to hit 70mph would take an act of GOD !!!! Possibly a QD70 but then you would be rolling it. I just dont think that boat would safely run 70mph.... Counter rotating QD35's (if they fit) - possibly.
A QD35 could take it into the low - mid 50's. More power than that is more weight. More weight needs more power.
You really want a 70mph social/sport boat ????? [sm=confused.gif]
Most riggers with exotic powerplants are lucky to see 70mph. AND Nothin RTR under $1500 would see 70mph. OR 60mph.... or 50mph
Old 10-14-2005 | 01:27 PM
How about a QD 140cc 4 cyclinder single engine? What do you mean roll the boat, from the torque.
Old 10-14-2005 | 06:03 PM
Ran the new Donzi today and it handles and runs great. I ran 3 full IV bags through it to get the engine broke in good. The engine starts easy with no problems. I tested several different props and trim tab settings and after about 12 or more launches, I got it like I wanted it to handle. No gps or tach readings, just breaking in and set-up. For sale for $900.00 without radio or receiver. I will not be making much, I just like to build them.
Old 10-14-2005 | 08:08 PM
Frogman - I was thinking of getting the hull to hit the desired speed - not trying to suggest the most exotic powerplants.
The 140cc QD would not work in the boat any better than a 70cc QD (Not that the 70cc would work all that well). There is a point where you over power a hull. On a Vee less than 60 inches your probably looking at the 10hp mark for most RC motors on the market.
Torque roll from a prop able to use the QD70 (probably a 7516/3 or 8016/3) would certainly want to roll the hull. And if you talk to any one who has powered such a hull with a QD70 you will hear that the boat rolls (not could roll - will roll). The bigger 140cc motor would be asking for a 9515/3 or similar - just not feasible.
Question - how many boats you seen with a 140cc QD ??? I would like to bet it is NONE. Because last I heard QD had sold two of those motors and neither went to a boating application.
The QD70 run through a counter rotating box may work but it is no different to running the two QD35's counter rotating as I listed above.
Old 10-14-2005 | 09:11 PM
ORIGINAL: FROGMAN524
The first thing you would have to do is mod. the hull and cap.
Old 10-15-2005 | 12:30 AM
Ron Olson's Avatar
[quote]ORIGINAL: DOOM!
A big waterfall!
Where's Dom at? He just rewrote the record books 2 weeks ago with his boat.
Realistically, you won't see 70 without a good hull, a great engine and a ton of prop work. krpnova built one at a cost of about $7,500.00 for a customer that has twin 70's in it and supposedly does 70 MPH, whether or not that it does, I can't say for sure. I've only seen pictiures of it.
Old 10-15-2005 | 12:51 AM
What did the QD 140cc engines go to? The torque is such and the prop bite is such that ifyou gave it instant acceleration from a stand still the boat would just do a 180 degress corque screw.
Old 10-15-2005 | 03:16 AM
I believe one was chromed and is now part of a motor collectors display (Japan I heard).
The other I do not recall.
A 57" hull is a handful with a 35 in it. A 70 would push it to its limit (and a little over it).
But hey - you got the coin [sm=greedy.gif] - grab a 140 and prove me wrong. I for one usually spend the money to try hair brained ideas but when it comes to the QD140 - it just aint worth the coin !!!
I believe the twin (Counter rotating) 70's are in an 84" bonzi hull. I guess there are a few of them in existence these days. The 3 QD70's powered 56" hulls I have seen were either wrecked or sold and all were rolled [&o]
Old 10-15-2005 | 06:43 AM
@ Ron
Listen to Justaddwata, he knows what he is talking about. The Magnum 57 would never handle those kind of speeds and you would over power the hull, and yes, it would take an "Act Of God"
I went 73.6 in testing here with this boat and set a new record a few weekends ago at 70.8 mph up in Flint Michigan. The old record was 64.8 mph with a J&G Motor in a Seaducer.
[link=http://p086.ezboard.com/fjimsrcboatdockfrm2.showMessage?topicID=4595.topic]AC Model Boats Razor 45 SAW Boat[/link]
[link=http://p086.ezboard.com/fjimsrcboatdockfrm2.showMessage?topicID=4694.topic]Italy SG Racing 35 cc SAW Boat [/link]
Good Luck
Old 10-16-2005 | 05:15 AM
hey...
what about a water jet.....there might be a chance... ?
Old 10-16-2005 | 12:50 PM
Where can you find water jets?
Old 10-20-2005 | 05:01 AM
I recomend the Super G for a cheap gas boat that goes in the 40's mph. And it runs $899.95 W/Radio that's installed.
Old 10-20-2005 | 04:53 PM
My Feedback: (13)
I have a magnum 57 with a cc racing engines pro modified 26 makes 6.5 hp and the boat runs about 50 some where in that range and that is about as fast as I would want to go with this boat it is a handful now if you trim it up I dont think you can get 70 mph out of this hull but I would like to see the video of it you dont know until you try go for it
Old 10-21-2005 | 12:35 AM
BMoneySL, I recommended the Super G to you? Thanks though, I tried CC racing engines site and it's under construction. I would like one of those engines in a Magnum 57, how much was it?
Old 10-21-2005 | 04:02 AM
Here is another great Engine Builder
[link=http://www.mddracing.com/Home_ban_Ls.htm]M&D designs Racing Engines[/link]
