RC Drifting Discuss all aspects of rc drifting here!
My new drift RIG(s)! PIX!
Old 11-07-2005 | 10:54 AM
mikewoodkozar's Avatar
Default My new drift RIG(s)! PIX!
Raining again here in michigan! So i have taken some pics (i know indoor pictures suck, but what can you do?).
First two pics are of my new 200mm rx-7 shell i have almost finished (have to add the exhaust yet-see it in the last pic!) It is sitting on top of a Factory Team TC3 with ultra wide dished wheels and ABS drift tires.
The next three are of my DRIFT rigs, the NSX is sitting on top of a TT-01 with dished wheels and ABS drift tires and lots of cool mods setup for drift. Note: the mesh grills on both cars. You like?
Then there is a pic of some freshly dished wheels i have made that will match up with the RX-7 pretty well i hope. I havent had a chance to put them on there yet and take a pic, but i will. I pretty much posted the pic of the wheels so you new guys could see how a dished wheel looks and how it adds depth to the wheel. Plus if done right it will allow propr fitment of 200mm bodies on 190mm based touring cars.
And finally the last pic is of the exhaust i made out of aluminum. I am still trying to figure out how i am going to mount it.
ID:	350176   Click image for larger version
ID:	350177   Click image for larger version
ID:	350178   Click image for larger version
ID:	350179   Click image for larger version
ID:	350180   Click image for larger version
ID:	350181   Click image for larger version
Old 11-07-2005 | 03:26 PM
Gamble Rumble's Avatar
Default RE: My new drift RIG(s)! PIX!
Wow, sweet collection, I love the NSX and the RX7 FD3S! Keep it up
Old 11-07-2005 | 06:03 PM
Thanks, soon i will post some pics of the TC3 topless. Man i need to find a way to mount the exhaust.
Old 11-07-2005 | 06:28 PM
[X(]i hate you
nice cars. THOSE RIMS MUST BE MINE. coo stuff and that muffler looks el coolio
Old 11-07-2005 | 07:45 PM
nice cars.
did u buy that body in carbon fiber? did u make the muffler? if so how?
Old 11-07-2005 | 09:27 PM
Yeah i got the body in carbon fiber trim on a popular auction site. And i made the muffler out of two old DecoColor paint markers. One fine tipped (for the tip) and one broad (for the actual muffler). See the DecoColor brand paint markers are made of aluminum. What i did was sand off all of the labeling (it was painted on, and kind of a pita to remove) and then cut the pieces to the right length at the ends (the side opposite of the tip) where they are butted. Therefore you should have two pieces now. Both should look like little metal cups, one short with a small diameter, and one longer with larger diameter. Then grind down the bottom of the two cups so they are flat. After they are flat on the bottoms, find the center of the bottom of the cup and drill a hole in both pieces. Now use a small bolt and nut and screw the two pieces together. You shold now have what looks like a muffler, and there will be a very large whole on the end opposite from the tip. Cut a piece of aluminum (the thicker the better) in the shape of a circle the size of the opening. Drill a whole in the center of that, put a bolt though it (in the picture you can see i am holding on to this bolt) and then push it snuggly into place. You shoud now have a scale size muffler. Just figure out how to mount it and your done! Oh yeah one more thing, remember to empty the paint out of the paint markers before you start. And if you have done this right and are rally accurate about the center lines of your holes and make sure your bolts are in the center of everything, you should be able to chuck the bolt end i a dremel and polish the whole thing up real easy! Good luck guys, i hope this helps.
Old 11-08-2005 | 06:09 PM
iwant240sx's Avatar
i love your rx7
Old 11-08-2005 | 06:13 PM
coolkid's Avatar
nice job man, love the rims, thats gonna look real nice on the track...
Old 11-08-2005 | 06:14 PM
Thanks, i was starting to think that i scared some people away with my description on how to make a muffler like the one i made.
Old 11-21-2005 | 10:22 PM
I still havent figured out a way to mount that muffler i made. Anybody have any suggestions?
Old 11-22-2005 | 01:26 AM
i have no clue but i will be makin one soon and i will tell u how i mount it if i can figure out away lol
Old 11-23-2005 | 05:58 PM
coolkid's Avatar
sry i messed this post up...
Old 11-23-2005 | 06:12 PM
coolkid's Avatar
here, i drew u a diagram that probrobly wont help, but just an idea.
Old 11-23-2005 | 08:17 PM
Yeah thats not going to work
Old 12-05-2005 | 03:19 AM
hey man i just got the stuff to make an exuast pipe the other day and on the bottme of the small pin its kinda rounded so ill have to find a way to make it flat but ne ways if u ffind a way to mount it pls tell i need to know and if i find a way i will elt u know asap thanx man for the awesome idea its so sweet
Old 12-06-2005 | 02:16 AM
hey man i finished mine and like the guy said i tried it well kinda i reemed a hole in the back where i wanted it and i made it a little wmaller than the pipe was so that it would fit snuge and it worked ill get pics soon im trying to think of anothe rway to mount it
Old 12-07-2005 | 05:28 PM
here are some pix of my pipe and how i mounted it i did on an old body so it wouldent mes up my good one im still looking for other ways i hope this helps
ID:	366440   Click image for larger version
ID:	366441   Click image for larger version
ID:	366442   Click image for larger version
ID:	366443   Click image for larger version
ID:	366444   Click image for larger version
ID:	366445   Click image for larger version
