MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
gasser 35 battery pack
Old 05-03-2006 | 08:35 AM
Default gasser 35 battery pack
sorry, I don't remember if this has been asked before,,,
can I use a 5 cell ni-cad on my MVVS 35 (red head) ignition ?? and, will I get more spark with a 5 cell ??
Jim
Old 05-03-2006 | 09:31 AM
Meesh's Avatar
My Feedback: (135)
Default RE: gasser 35 battery pack
Some are 4.8V only. I recently got one that says 4.8V or 6V
I'd use 4.8V to be on the safe side.
Bob
Old 05-03-2006 | 09:39 AM
DarZeelon's Avatar
Jim,
With the new twin-magnet Vlach (or MVVS) ignition systems you can use from 4.8 to 6.0 volts of nominal pack voltage.
This would mean either a 4-cell, or a 5-cell pack is good.
With a higher primary voltage, the secondary voltage would be higher, which does mean a stronger spark.
Old 05-03-2006 | 10:56 AM
a stronger spark gives better performances?
Old 05-03-2006 | 11:22 AM
DarZeelon's Avatar
No, Paolo.
If ignition occurs, a stronger spark will not make more performance.
It does offer slightly easier starting in border-line mixture situations.
This means the engine, before it is perfectly adjusted, would be more likely to fire.
...Less flipping is an improvement.
Old 05-03-2006 | 01:47 PM
thanks, I'm going with a 5 cell, more spark will help it start better..
Jim
