JL F-18 modification
Hi friends:
I am working in a F-18C kit of Jet Legend, but I change to "B" version, for this reason I make some modification.
I hope that you like and tell me anything.
photos...
photos...
RE: JL F-18 modification
+ photos...
This is a F/A-18B version.
The difference in A/B and C/D version are minims. A lot of panel lines are in bad possition. The nozzle details are mistaken. The infly refueling prove panels are mistaken too. The panel access in the side of fuselage has a small hinges that no are estimated, but in the kit are to much big. and a lot of details that no are to scale....
I´ll like to make the best job possible.
Regards from Spain.
Regards from Spain.
Hola Enrique & company:
Si, esa fue la zarón de hacelo biplaza.
Yes, that was the reason for make it twin seat.
Un saludo.
Regards.
Un saludo.
Regards.
Hi John:
I get the canopy from Tam Jets. the shape in the B/D version is almost equal that the F version.
When I advance, I will put more photos.
Regards from Spain and thanks for your words.
[sm=49_49.gif][sm=49_49.gif]
Pois,pois, Carlitos...
Como diz o teu pai: É só ordenador, é só ordenador, como c... vá a tener os aviones listos? [>:][>:][>:]
Vamos encontrar-nos na Irlanda?[sm=shades_smile.gif]
Hola José:
Por supuesto que si. Espero que me llegue pronto las nuevas bancadas de los estabilizadores. Estoy esperando por el tren de Jet Power mientras termino el arreglo del Hotspot.
Of course. I hope that come soon the new mount for horizontal stabs. I am waiting for the Jet Power landing gear while I arrange my Hotspot.
Ya tienes el Fouga Magister? pon fotos!
Have you the Fouga Magister? put photos!
Un saludo.
Regards.
Un saludo.
Regards.
Hi:
I have the new wheels for my Hornet.
I hope that you like.
Regards.
__________________________
Carlos.
Regards.
Carlos.
Hi again:
I put the photos of the canopy details.
http://www.rcuniverse.com/forum/m_4939048/tm.htm
Regards from Spain.
Regards from Spain.
Hi:
The rig of the horizontal fins are from Jet Legend, I am waiting still for this items, I hope that come to me the next week. I don´t know what happen with the dealer for Europe (Germany) I am waiting for this 4 month.
www.jetlegend.com
Regards from Spain.
www.jetlegend.com
Regards from Spain.
Hi:
I am not sure that you want to see. I put 2 photos. If you need another, plese, tell me it.
The nose is empty because I extracted the lead in the nose.
AB, CANADA
cmjets, can you explain to me how you made the hinges work on the canopy. I was looking at using robart hinges but then when you lift the canopy it will hit the back of the fuse. Please post some pics if you can.
Hi Dig it:
The hinges in the canopy are like the gear doors, but made home.
I made one in plywood for test and them I made it in fiber glass. (electrician circuits).
I put photos of the hinges and the block system. I use a Hitec 645MG for the moviment and HS 81 for the block with a secuencial door system. I swich up and the block is retired, them the canopy is open and when I swich down, the canopy down and them the block is out.
Now I am painting the model, when I install the servos again, I will put a video from inside.
Regads.
Regads.
AB, CANADA
hmmmm, I see. Now, can you tell me. The "simulated" canopy hinges at the rear of the canopy, do they bind at all, or simply lift with the canopy?
Dale
Dale
Hello Friends:
I follow the construction of my F-18. I have a refuel probe.
I put photos and video.
Enjoy
http://www.youtube.com/watch?v=wJU5jAlnkLA
Carlos.
___________________________________
http://cmjets.blogspot.com/
Enjoy
Carlos.
My Feedback: (9)
ORIGINAL: cmjets
Hello Friends:
Enjoy
Carlos.
Hello Friends:
Enjoy
Carlos.
Extra Uptight...
Hi again:
Now is really finished. I put 2 swich for the light.
I put another video.
http://es.youtube.com/watch?v=S0kx-RMp3MY
Regards from Spain.
Carlos.
Regards from Spain.
Carlos.
Hi Mike:
Yes, I need a KC-10 !!!
Inside I have a brass in 4 mm for fill the Kero, but I think that no is suitable for every days, because the system no is strong enough.
Regards.
Regards.
