Cox 049 seized? Or is it? What to do?
MA
HI ALL!
I have an old COX 049 engine. I can't pull that little cord. Is it seized? If so...can I popur good old MArvel Mystery oil in it? OR...just how does one get this thing open???
Many thanks, Ted
Many thanks, Ted
If you are having trouble with it being gummed up, you may have to disassemble it and clean the needle assembly and the reed before running it.
George
George
I had the Cox engine with pull starter. Do not dismantle the pull starter! Soak the engine overnight in fuel, this will soften the hardened castor oil inside it.
Jens Eirik
Jens Eirik
MA
Hi all for the responces!
Just HOW do I soak it??? I know it sounds STUPID! Right now the engine is in a Testors Sprite 500 car. I don't want to take it apart unless I (ya, STUPID, me) can figure out how to CORRECTLY soak it!
MANY THANKS, Ted
MANY THANKS, Ted
ORIGINAL: RCtedII
MANY THANKS, Ted
MANY THANKS, Ted
Take the engine of the model car and soak the whole engine without glowplug in fuel overnight (not in fuel can, use own container since fuel can not use again after the engine are soaked in this fuel).
Jens Eirik
