 JETMACH - TURBINE TRAINER BUILDING >
Old 12-05-2006 | 06:43 AM
cel
Default JETMACH - TURBINE TRAINER BUILDING
HELLO GUYS. I WILL START THIS THREAD TO SHARE MY EXPERIENCE IN BUILDING MY FIRST TURBINE JET TRAINER. THE MODEL CHOSEN IS JETMACH 60 , AN ALL WOOD TRAINER JET BY BOB LESERVE - WWW.LASER-DESIGN-SERVICES.COM. THIS IS AN ALL WOOD KIT THAT SEEMS TO BE VERY EASY TO BUILD AND FLY. FIRST I WOULD LIKE TO SAY THAT BOB LESERVE IS A GREAT GUY AND HELPED ME IN EVERY ASPECT OF THE PURCHASE AND GIVE ALL THE NECESSARY FEEDBACK. THIS IS AN WOOD AIRPLANE WITH 80 IN WINGSPAN AND 75 IN LENGHT. IT HAS AN ALUMINUM WING JOINER TUBE AND MAIN LANDING GEAR. A HEAT SHIELD, ALL STOCK WOOD AND A WOOD LASER PACK. THE WOOD SELECTION IS VERY GOOD AND THE LASER CUT PACKAGE IS GREAT. I WILL POST PICTURES OF THE BUILDING AND WOULD LIKE TO RECEIVE FEEDBACK WITH SUGGESTIONS AND WITH OTHER PEOPLE THAT PURCHASED AND BUILT THE JETMACH. I WILL BE IN CONTACT GUYS.
CELSO
Old 12-05-2006 | 06:54 AM
cel
Default RE: JETMACH - TURBINE TRAINER BUILDING
WE STARTED THE CONSTRUCTION BY THE WINGS. THEY ARE BUILT OVER THE PLANS. IT IS A SIMPLE CONSTRUCTION , BUT MUST BE VERY PRECISE AND WELL GLUED. THE INSTRUCTION MANUAL IS COMPLETE AND EASY TO FOLLOW.
Old 12-05-2006 | 07:10 AM
rcguy!'s Avatar
My Feedback: (69)
Can you kill the CAPS? It's painfull to read.
Photos?
Dave
Old 12-05-2006 | 07:21 AM
cel
I WILL POST PHOTOS IN THE AFTERNOON. REGARDS
Old 12-05-2006 | 07:53 AM
My Feedback: (10)
ORIGINAL: cel
while you are building it
maybe you can buy his also.
will save us reading glasses : http://www.microsoft.com/hardware/mo...ialoffers.mspx
Old 12-05-2006 | 10:32 AM
cel
Here are the wing assembly photos. The wing is built over the plan on a flat surface, as right and left pieces and then are joined together with an aluminun wing tube. You can see the laminated ribs, the wing tube support doublers. Make sure that the main wing spars is straight and aligned on the plans. Position the ribs on the plan with tabs down. The ribs must be aligned . You have a dihedral gage. You must abrase the wing tube before you glue it. We are starting the leading edge sheeting. I think that by end of the week i will have the wing almost ready. The construction is straight and you just have to follow the manual. Any coments would be great. I will post more photos as the construction goes on. Regards
Old 12-05-2006 | 10:38 AM
cel
MORE PHOTOS
Old 12-05-2006 | 10:47 AM
cel
PHOTOS
Old 12-05-2006 | 11:15 AM
ghost_rider's Avatar
My Feedback: (20)
Cel
I just edited post #6 to remove of caps in you post. It makes it more readable in that format.
Are you having problems posting your pictures? Please let me know and I will PM you details on how to do it.
Regards
Ben
Old 12-05-2006 | 11:25 AM
cel
Sorry guys. I am having problems posting my photos.
ID:	572067   Click image for larger version
Old 12-05-2006 | 12:25 PM
cel
Photos.
ID:	572076   Click image for larger version
ID:	572077   Click image for larger version
ID:	572078   Click image for larger version
ID:	572079   Click image for larger version
ID:	572080   Click image for larger version
ID:	572081   Click image for larger version
Old 12-05-2006 | 12:29 PM
Shok's Avatar
My Feedback: (28)
Cel, what motor will you be using?
Old 12-05-2006 | 12:30 PM
cel
More photos guys. I have just started the wing sheeting.
ID:	572083   Click image for larger version
ID:	572084   Click image for larger version
ID:	572085   Click image for larger version
Old 12-05-2006 | 01:13 PM
cel
Hello Shok. I will use a Modellbau T500, that i purchased from a guy here in Brazil. It seems to run ok. Any information would be great, because it is my first turbine jet . Regards
Old 12-05-2006 | 02:32 PM
Shok's Avatar
My Feedback: (28)
thats plenty of power for this plane
it will fly fine
Old 12-06-2006 | 05:45 AM
cel
Hello Shok. What would be the top speed at level flight with the Modellbau t500. Regards.
Old 12-06-2006 | 08:10 AM
Shok's Avatar
My Feedback: (28)
120-140mph
Old 12-06-2006 | 09:10 AM
erbroens's Avatar
Nice to see the pics of your jet project here, Cel ... keep the pics coming and good luck with it!
120- 140 mph is plenty fast for this kind of plane... and you can always chop the wings later if you feel the need for more!
Enrique
Old 12-07-2006 | 01:59 AM
flybye33's Avatar
We're building two in Brisbane Australia. One as per the book and the 2nd one with a foam wing and a few minor mods for looks, like a "proper" curved canopy etc
Some points I've found:
Read through the book, then read it again. Check out the images on the enclosed CD.
Cut or score the laser break points on both sides of the push outs for minimal clean up
There are a quite a few parts that benefit from dry fitting first.
Particularly the fuse sides. In order to get perfect alignment file the finger joints for a slide together fit first. (A flat file will give you a flater surface and gets into the corners better. Sandpaper tends to round the edges.) This gives a little room for alignment with both sides and allows the ply to lay flat when gluing. Mine was too tight and warped the assembly, so that's what I did.
Like Bob sugests, I love white glue for ply.
I'm not going to "film" mine, strictly a glass and paint man. With a steel shed and 40 degrees C, that plastic stuff is just tooo much trouble.
Brian
Old 12-07-2006 | 07:21 AM
cel
Thanks Enrique for your feedback. I will post more pictures soon. Stay Tuned. Regards
Old 12-07-2006 | 07:26 AM
cel
Hello Brian. Thanks for your interest. It would be great if you send pictures of your Jetmach. I have interest in details of your foam wing and your `cosmetic ` mods. Keep me posted. Send your pictures. Regards
Old 12-07-2006 | 07:28 AM
cel
Hello Ronnie. Great numbers. I don´t see the time to fly mine. Regards
Old 12-07-2006 | 09:02 AM
limeybob's Avatar
Brian, many thanks for the constructive input, I'll look at loosening the fit of the tongues. Would a loose fit be OK, I was concerned about keeping the fuselage sides straight with out having to use a straight edge to align it.
The fit of the wingtube is designed to be tight, this is now proving to be a good thing as the two piece wing is about to be flight tested. It passed the static load test with no problem.
Regards
Bob
Old 12-07-2006 | 09:44 AM
FalconWings's Avatar
My Feedback: (57)
ORIGINAL: limeybob
Regards
Bob
The static load consists of hanging the wing from one chair at each wingtip, then Ronnie sits in the middle.
For the fatigue test, Ronnie bounces up and down to the rithym of La Macarena.
See you soon guys.
Old 12-07-2006 | 10:07 AM
Shok's Avatar
My Feedback: (28)
HAHAHA
Message for moderators:
Is it ok for me to post pictures of the current one I am building in this thread as well?
