Hitec/MultiPlex Radios- Ask Hitec Customer Service Ask Hitec/MultiPlex Customer Service your Radio questions here.
dual elevator servos
Old 12-21-2006 | 05:59 PM
My Feedback: (10)
Default dual elevator servos
hi:guys i am useing a eclips 7 radio and a 6ch. rx. how can i setup 2 servos for the ele. without a y harness? useing 2 seperate chanels. thanks
Old 12-21-2006 | 09:18 PM
My Feedback: (31)
Default RE: dual elevator servos
The Eclipse TX's provides two distinctly different paths to dual elevator mixing; TX production/age dependent.
Some late model Eclipse TX’s inexplicably realized software changes and NOW offer a feature/function called out as “AILV”. AILV is a pre-programmed factory MIX with trims linked between channels. (AILV is not noted in the Eclipse manual; see the link below to the Optic 6 manual)
Earlier Eclipse TX’s are limited in this regard, it’s doable with a P-mix BUT the AUX channel trim is not linked to the master mix channel and a switch must be active ALL the time.
See the manual for more info on same. If you don't have a manual, click on the link below.
http://hitecrcd.com/Support/Manuals/Radio/eclipse.pdf
The Optic manual on page 39 desribes the AILV feature:
http://hitecrcd.com/Support/Manuals/...Manual%202.pdf
