RaidenTech/NitroPlanes Yak 50cc (Build).. Maybe?
FL
RE: RaidenTech/NitroPlanes Yak 50cc (Build).. Maybe?
frieshoo,
What WH Egde 73" or 80" span , 28% or 30 % WH Edge for CF Tube because I've seen at Troybuilt and I might buy both CF landing gearand CF wing Tube. Thanks.
FL
frieshoo,
What size of the WH Egde? 73" or 80" span [28% or 30"] CF Tube? because I saw Troybuilt webside ,I might get both CF landing gear and CF wing tube,Thanks.
My Feedback: (20)
VA
The Yak got it's maiden flight today.
It was very windy at my field. 20+ MPH winds.
Wierd day. Wind gusting, and then no wind at all. So, I decided to fly the Yak.
I was nose heavy (hard to believe, since my engine is a very light Evolution 45, with a pitts muffler)....
The Yak was locked in right off the patch. She is light, and had a good light feel on the sticks.
IMAC stuff was solid, and very crisp. I had some slight blow back on the rudder.... This could be my servo... or geometery on the pull... or it could have been wind.... My tail 'wiggled' on half throttle fly by's.
3D rates, the Yak is at home.... IMO, if you want competition IMAC... buy something else... But if you want to hover, torq roll, and harrier around... this yak is as good as any I have flown.
Again, it was windy, and gusting.. but this arf has a nice balance to it on 3D rates.
I was snapping it 10 feet off the ground, and pulling into a hover with ease....
I gave the radio to a TOC guy, and he put on a show.
He didn't like the inverted characteristics of the Yak... (but it's nose heavy)...
He did a rolling harrier to the right... about 2 feet off the deck.
Final note:
I installed the STOCK WINGTUBE, and I did back, to back BLENDERS with it.... It held up.
Final note:
#31
FL
Good job frieshoo ! even it was a windy day but sounds still good to me ,it's only nose heavy matter.For me if wind gust 17-20 mph. and I will never try this air plane at all and I always flew my Kangke Cap 232 sports, it loves wind. But I am still close to an immediate pilot and have started flown since march 2005. It' about two years now. That why I always looking for this thread to help me working on my first 50 cc gasser size. I have almost all kinds of airplanes you name it ,Extra 66",Mustang 75",Edge 75",Sukhoi 75",Super Chipmunk 65", Great Planes Giant scale Ultimate ,Cap 232 sports 65",Ultra stick 64" it but still need more experience .I hope you guys don't mind to come back on this thread with the next flight to give me feel more confident and secure on this Chinese Yak 54.. Thanks alot.
#32
FL
frieshoo ! how is the DL 50 running ? and how do you like it so far. If t's a good stuff I'd to have one for my yak 50cc at Peak Model w/ free shipping. Please let me know , Thanks.
#33
FL
My Yak came in today w/ the big double box ,opened it up ,no damage [ lucky ]. I tried to assemble wings and stab all fit good so far and I don't have to cut the wing tube. I have odered Hitech 5645 MG for hi-torque where they needed and use Hitec 425 BB for throttle, a guy at the field has 30 % Extra 260 almost the same size and he doesn't use coated steel wire for pull-pull rudder wire and he uses some kind of material that will not introduce RF interfierence . Are you using supply pull-pull cable? if it has no problem I want ot use the stock one. Thanks.
#34
My Feedback: (20)
VA
Suntan,
I used the stock pull-pull cable. I crossed them, and they don't touch. I used a 3" double arm on the servo.... I have plenty of Rudder throw...
I just got my DL-50 back (I fried my ignition.. my fault, not the engines fault LOL!)... I have a Evolution 45MG on the Yak... but a DA will be going it as soon, as I get mine back from DA. My DL-50 is my WH Edge now.
Talk to you later.
Dennis
Talk to you later.
Dennis
#35
FL
frieshoo;
I started applied CA all over the places like you said and using triangle balsa beef around the engine block with epoxy and now it's solid. I also tried to mount the hatch it was a little bit difficult like you said but I found a better way to insert the screws in to the hole by cut a 2 " of large fuel tube and insert the head of screw in the fuel tube and now you can eaily screw it in by turn the tube and when it catches the first thread then you tightened with the allen wrench,it work out very well no broblem at all. Try that. Now I am waiting for 3MM,TOC 53 CC.engine ,at first I have just about to order DA 50 from Troy built which very close where I live but I have seen so many people talk lots of good things about this engine so I desired to bought this one as a matter of fact it's sold out have to wait until next week and cost only $ 419.00 w/ free shipping and also the dealer locate in US. Ohio, they support and carry the parts too. But after I 'm getting familiar w/ gasser then I will get the best one like DA. See -- Yaa and thanks for your info.
#37
My Feedback: (20)
VA
The 3MM is a very good engine (at least the two I have ran). The guys are running a NX 23x8 on them. Much better 'appearance' than the DL50... and seems to be stronger. You made a good choice.
#38
FL
Hi ;frieshoo; I almost done with my Yak 54,50 CC [Nitro Yak or Raidentech Yak] I weighed it today w/ my bathroom scale, I got 16 lbs. minus two switches and this is only a roughly set up because I'm waiting for XOR 22x8 prop and two switches but right now I installed 18x8 master airscrew on with 4" Tower Alu spinner, but the XOR may be much lighter than the composite Master Airscrew prop.What do you think if it comes out alittle bit more than 16 lbs?
Is this Yak 54 a mid-wing or low wing airplane ? If it's a mid-wing and how do you check the C.G ? Right side up or invert it. Thank you.
#39
My Feedback: (20)
VA
Right side up.
I'm at about 16lbs. It's a rocket.... I put my DA50 on it.... can't wait for the wind to stop!!!!
#40
FL
Thank you very much ,frieshoo , and will let you know about her maiden flight and how the 3MM,TOC 53 CC. engine run, it's a good looking engine and I also finished my GP giant scale Ultimate with the new 46 GT from Scott Brillelli and also waiting for XOR 22x8 and 21x8. See you later.
#41
FL
Hi; frieshoo ! what kind of prop jig you use to drill the prop holes for 3mm,toc 53 engine ,some one said the ZDZ 80 prop jig is the perfect match but has to use the dill bit larger i.e 5mm instead of 4mm. Thanks again.
#42
FL
Help!!!! I could not get my C.G ,it tail heavy ,I used GP balancer and used my two fingers underneath the C.G marks. The tail was heavy and never moved at all . You said you power your Nitroplane YAK-50 CC with DL-50 but I checked the DL-50 specs. it's about the same weight more or less. Have you got the C.G ,OK.? I did it right side up and I don't know what to do , I've never ran into this kind of the problem before because it's way way out of spec. What did I do wrong .Please help! everybody if you see this thread. I 'd like to fly my Yak [ Niyroplane Yak-50 CC ] Here 's my set up ;
-3MM TOC,53 CC Engine
-2x 2100 mah NiMH, [ for RX & Ignition ] Both baterries and Ignition mounted on engine box
-7 x Hitec servos [ 2-for aileron,2-for elevator,1-for rudder,1-for throttle and 1- for Choke ]
-1 x Futaba Rx. [ temporarily for test and waiting for Futaba 2.4 Ghz. spectrum ]
-Dubro pull-pull rudder sytem
- 22x10 Xoar
-4" GP aluminium spinner
-Stock alu. wing tube and stab.
-Stock landing gear
-Stock tail wheel ass'y
-Dubro giant scale black nylon hinge system [ Post stye ] for elevator and aileron
So that's about it and nothing fancy at all. Please give me some idea and what I have done wrong and what to do next to get this baby fly soon. Thank you very much.
- 22x10 Xoar
-Stock landing gear
#43
My Feedback: (20)
VA
SunTan,
I balanced on the wingtube. I didn't get a manual with my Yak so I didn't know the factory CG. My Yak is perfectly balanced (inverted flight, no elevator need for level flight...etc..)
I didn't use the stock tail wheel. I used a Haigh tail wheel from Wildhare. (It weighs less than the stock one).
I have JR 4721's on the elevators, rudder (pull-pull), and ailerons.
DA50-r, pitts muffler.
1 nihm RX battery (a big one)
1 nimh ignition battery on the motor box.
If yours balances on the wingtube, you will be fine.
#45
My Feedback: (20)
VA
suntan,
I forgot one thing that might help.
My DA prop hub is 1" past the cowl opening. I do this on all round cowling ARF's. It helps with cooling, and prop efficiency.
#46
FL
Thank you freishoo, for the info, I checked mine and I got 3/4" from cowl opening to the alu. back plate. I didn't use the stand off for my 3mm,Toc. It should be O.K right? I have to add the whole 6 cells Tx batt. in the fuel tank compt. I removed the stock tail gear and replaced w/ light weight Dubro for 16 t0 30 lbs plane. The instuction manual that they e-mailed to me it says 165mm. for CG. and its's exact at the wing tube like you told me. Finally I gave her first maiden flight on last friday morning, belief me I was so worried and also the 3mm,TOC. doesn't have a good mid range. I decided to go for it anyway and I was taxing around to make sure it has a good ground handling, then I added 3/4 throttle about half of the runway and she left off. I felt like it's heavy ,I made a right turn and her nose dropped I have to gave more elevator to keep her flying level and I decided to bring her down. Landing was good ,no stalled and it's still one piece and a guy at the field told me he was very shaky . I will try her out again next week sometime.May be this time I feel more comfortable.
#47
My Feedback: (20)
VA
I think after you get the engine running a little better, you will like the yak. Sounds like you might be a tad nose heavy, but don't worry about that until you get the Yak trimmed out, and the engine running reliable.
Yeah, You don't have to use the standoffs (stock) to mount the engine. I guess you cut a big hole in the firewall?
#48
My Feedback: (20)
VA
ORIGINAL: zayzay1
so how does this yak compare to one of the more popular brands say sd models or aerotech
THe hardware sucks (well, mine did)... It's built very light, and fragile... but I like a ARF built to fly not crash.
I have never flown a SD Yak, or Aerotech, Aeroworks... so I can't help there.
#49
What standoffs are you guys using with a Da 50 on top 2 1/2 " or 3".
thinking of buying as my first 50cc project! do you guys recommend it?
manyu
manyu
