 RT Aerospace 1/5th T-34C Build >
Old 09-06-2007 | 10:30 PM
TLH101's Avatar
My Feedback: (90)
Default RT Aerospace 1/5th T-34C Build
Finally finished my P-39 and got the shop reasonable clean, so it's time to start a new project. I won't really dive in until after I return from Bomber Field next weekend.
Got a Ramon Torres Aerospace T-34C kit, with the "honeycomb" glass fuse. This fuse is really neat with the honeycomb. Very light, but super stiff, even without the bulkheads installed. Such that they are, the 2 rear bulkheads are 3/8" blue foam, and there is a 1/8 thick plywood ring that fits in front of the wing saddle. More info can be found here: http://rtaerospace.com/Beechcraft_T34A_kit.htm
The first pic shows all the cut wood parts, next are some pics of the fuse & cowl, with some inside shots to show the honeycomb. The next is a shot of all the plastic parts. They are molded in a really rigid and thick ABS plastic that is pretty lite. Parts include a scale spinner, tail cone, exhaust stacks, wing tips, stab & fin fairings, inner & outer main gear doors, and wingtip lite lenses. Plans are 2 pages that are really well drawn.
ID:	757998   Click image for larger version
ID:	757999   Click image for larger version
ID:	758000   Click image for larger version
ID:	758001   Click image for larger version
ID:	758002   Click image for larger version
ID:	758003   Click image for larger version
ID:	758004   Click image for larger version
ID:	758006   Click image for larger version
ID:	758007   Click image for larger version
ID:	758008   Click image for larger version
Old 09-06-2007 | 11:07 PM
My Feedback: (101)
Default RE: RT Aerospace T-34C Build
Heck man, I aint got over your last build yet....... I think I shall dub thee....."Steamer", Old Fart in training doesnt do you justice. I can t wait to see how you do this one.
Old 09-07-2007 | 05:55 PM
TLH101's Avatar
My Feedback: (90)
Worked on spars today. Calls for 1/2 x 3/8 hardwood for the wing spars, top and bottom, that tap[er to about 5/16 at the tip rib. That's a lot of weight, and I don't have any hard wood stock in those dimensions. So....... I am making my own laminates. I am using 2 pieces of 1/4 x 3/8 balsa. I am laminating them together, with a strip of carbon fibre in between. Makes for really stiff spars, that are 1/2 the weight of the hardwood.
And easier to taper.
ID:	758541   Click image for larger version
ID:	758542   Click image for larger version
ID:	758543   Click image for larger version
ID:	758544   Click image for larger version
Old 09-22-2007 | 11:39 AM
TLH101's Avatar
My Feedback: (90)
I don't plan to do a complete step by step build on this, but since I have never used a wing jig, and, I am sure a lot others have not, I will show this portion step by step. I am using an original Adjusto-jig. My kit was designed to be built on this jig so all the holes were already drilled.
First pics show the mods I had to do to the retract mount doublers for the CJM retracts. I'm not a fan of CJM, but I've got them, so in they go.
Next pic shows the the jig set-up with correct spacing for the ribs.
Now all the ribs are installed on the rod ans placed on the jig. You need to make sure all are on the correct side of the red rod mounts. The rods are held down with rubber bands.
Next, straight pieces of stock are clamped to the trailing edge of the ribs, to create a perfectly straight T/E, and the leading edge is glued on. I will be doing most all of the wing build with Aliphatic Resin glue, (no odor and easier to chew the residue off the fingers).
The spars are added, and glued in place.
ID:	767634   Click image for larger version
ID:	767635   Click image for larger version
ID:	767636   Click image for larger version
ID:	767637   Click image for larger version
ID:	767638   Click image for larger version
ID:	767639   Click image for larger version
ID:	767640   Click image for larger version
Old 09-22-2007 | 12:05 PM
TLH101's Avatar
My Feedback: (90)
The first 2 pics show the left wing after all the shear webs have been installed, and the spars have been planed down to the correct taper. It is now complete enough to remove it from the jij.
I will put it back on when I begin to sheet it, and complete most of the sheeting on the jig.
Next are some pics of the retract mount, and pics of the plans showing the original retract set-up. You can see why I had to make the changes noted above.
ID:	767647   Click image for larger version
ID:	767648   Click image for larger version
ID:	767649   Click image for larger version
ID:	767650   Click image for larger version
ID:	767651   Click image for larger version
Old 09-22-2007 | 12:10 PM
TLH101's Avatar
My Feedback: (90)
Here are some pics of the engine cooling duct. I was messing with it so I thought I would post them. The duct is a fiberglass piece the ducts the cooling air from a hole in the firewall behind the cylinder, to a scale opening on the fuse side. I have not cut any holes in the firewall yet and the duct is just set in place to "see how it fits".
The last 2 pics are of the piece cut from the fuse outlet opening. Really gives a good idea of how the honeycomb looks.
ID:	767653   Click image for larger version
ID:	767654   Click image for larger version
ID:	767655   Click image for larger version
ID:	767656   Click image for larger version
ID:	767657   Click image for larger version
ID:	767658   Click image for larger version
Old 09-22-2007 | 12:13 PM
TLH101's Avatar
My Feedback: (90)
Here's what the outlet looks like on the full scale.
ID:	767660   Click image for larger version
Old 09-28-2007 | 12:38 PM
TLH101's Avatar
My Feedback: (90)
OK, here's some shots of the method I am using to simulate the corrugations on the control surfaces. The pieces will be the rear sheeting for the top of each wing panel. The same will be done with bottom sheeting for each wing half. Also the stab, elevator, fin & rudder. This idea came from a build thread for a T/F T-34 on RCSB.
I reshaped the grinding stone tip so it has a bit more radius, to keep the correct shape. All the rulers and yard sticks are held at at the correct spacing to keep all the ends lined up.
ID:	771986   Click image for larger version
ID:	771987   Click image for larger version
ID:	771988   Click image for larger version
ID:	771989   Click image for larger version
ID:	771990   Click image for larger version
ID:	771991   Click image for larger version
ID:	771992   Click image for larger version
ID:	771994   Click image for larger version
Old 10-11-2007 | 12:44 AM
Any More going on with this project....Boston Legal, the Golf Channel and your build are the only things worth watching these days?
PS T-34C "Stud" 1978-early '79 (when they were all crashing due to spins and lack of an EPL) VT-2
T-34C Instructor VT-10 1983-1985 (Teaching the NFO's (self loading baggage) to navigate)
Old 10-11-2007 | 11:16 AM
TLH101's Avatar
My Feedback: (90)
Default RE: RT Aerospace 1/5th T-34C Build
Not sure I am going to continue the build thread. Based on the number "views" the thread has, there just does not seem to be very much interest in this build.
I have not done very much since the last installment, as I have been getting my "weekend" flyers up to snuff. Our best flying season is just now starting.
If there is some real interest in it, I will continue the thread, when I put it back on the bench, in the next couple of weeks.
Old 10-11-2007 | 11:33 AM
mimoore67's Avatar
My Feedback: (51)
Oh, don't do that! At least post pictures! I'm bashing a little H-9 T-34 by adding flaps and hopefully scaling out the retracts! Still looking for a 105 degree good mechanical nose gear! I bought some good 85 degree mains! I love reading about different Military models!
Old 10-11-2007 | 12:10 PM
My Feedback: (60)
I'm watching Terry, keep at it.
Old 10-11-2007 | 06:33 PM
Well, I hope that you continue. Not a complaint or anything but it might be an issue (re: not a lot of hits) because the posts by yourself are spread out. Having said that, I, like most "reasonable" people
realize that these scale projects don't go together overnight and that we all have other lives to live. I appreciate your work, especially as I have been in posession of a Torres T-34C for near 6 years and
have only been able to work on it a little bit at a time due to my job. Therefore...I hope you continue to post your progress on this forum. Ifnothing else a simple explanation of photos maybe.
Thanks...Mike
Old 10-25-2007 | 10:44 AM
TLH101's Avatar
My Feedback: (90)
OK, seems there are some who have an interest, so I will continue. I have not done much work lately, but I have sheeted the tops of the wings. Also sheeted the bottom rear areas, so i can start on the control surfaces. I will cutting the ailerons and flaps loose. I am going use scale hinging on both. The plans call for using plywood, to make the aileron hinges, and aluminium to make the tracks for the fowler style flaps. I picked up some .060", FR-4 board, that is similar to G-10 and plan to use that. It super stiff, but seems to cut and work really clean. The last pic shows the FR-4.
More to come
ID:	790059   Click image for larger version
ID:	790060   Click image for larger version
ID:	790061   Click image for larger version
Old 10-25-2007 | 10:56 AM
TLH101's Avatar
My Feedback: (90)
Here are some shots of the plans and patterns, that show the small hinge parts I will need to make, and how they will be installed.
ID:	790074   Click image for larger version
ID:	790075   Click image for larger version
ID:	790076   Click image for larger version
ID:	790077   Click image for larger version
ID:	790078   Click image for larger version
Old 10-25-2007 | 06:45 PM
mimoore67's Avatar
My Feedback: (51)
Enjoying reading your thread! I'm too am a fan of the T-34, however I'm just hacking around on a little H9 T-34, that I am currently "ARF Bashing" on the work bench! Just finishing up the flaps, which I'm still working out the engineering details on how exactly to extend and retract! I'm also using your thread, to get ideas on how build and engineer things! So keep up the posts and Pictures!
Michael
Old 10-28-2007 | 03:05 AM
Thanks for continuing...appreciate it
Old 10-28-2007 | 08:40 AM
NickC5FE's Avatar
My Feedback: (31)
What is the price of the "Full" kit. The RT website is a littleconfusing at pointing out this option. All i see is the Semi price. Nick
Old 10-28-2007 | 12:56 PM
TLH101's Avatar
My Feedback: (90)
There is no "full" kit. All he produces are the cut wood parts, glass fuse, and accesories.
Old 10-28-2007 | 01:44 PM
TLH101's Avatar
My Feedback: (90)
Here the start of the flap and aileron builds.
ID:	792210   Click image for larger version
ID:	792211   Click image for larger version
ID:	792212   Click image for larger version
ID:	792213   Click image for larger version
ID:	792214   Click image for larger version
ID:	792215   Click image for larger version
Old 10-31-2007 | 01:42 PM
TLH101's Avatar
My Feedback: (90)
Here's the aileron build up and hinging.
ID:	794137   Click image for larger version
ID:	794138   Click image for larger version
ID:	794139   Click image for larger version
ID:	794140   Click image for larger version
Old 11-01-2007 | 08:05 PM
TLH101's Avatar
My Feedback: (90)
Decided, that since all the other controls will be hidden on this model, the ailerons should be too. So here's how it's done, per the instruction manual. Hardest part was making that pully with out a lathe.
I also included a scan of the instructions which help make the pics easier to understand.
ID:	794993   Click image for larger version
ID:	794994   Click image for larger version
ID:	794995   Click image for larger version
ID:	794996   Click image for larger version
ID:	794997   Click image for larger version
ID:	794998   Click image for larger version
Old 11-01-2007 | 08:41 PM
My Feedback: (13)
Looks good Terry. I guess we will see it someday in the skies over Robstown! I known we've seen many at home, lol (inside joke, we both live near NAS Corpus Christi).
jpflyer
Old 11-01-2007 | 09:19 PM
great and interesting work....
Old 11-14-2007 | 12:13 PM
TLH101's Avatar
My Feedback: (90)
Started on the flaps. These pics show the mounting and the sliders. Need to pick up some tubing, and brass stock, before I can build the to torque rod actuators. Will post pics of those when I get them going.
ID:	803744   Click image for larger version
ID:	803745   Click image for larger version
ID:	803746   Click image for larger version
ID:	803747   Click image for larger version
ID:	803748   Click image for larger version
ID:	803749   Click image for larger version
ID:	803750   Click image for larger version
