Falcon gap
Hey Eric,
What distance should the Falcon tail cone (or any other part I can get a measurement from) be from the opening of the actual pipe on the Flash?
Thanks.
Thanks.
My Feedback: (10)
FL
Hi Mark. . .
Good Question and I will post our recommendations for all to read.
Happy New Year and the best to you and your family . . .
Distance measured from the outer nozzle to the entrance of the actual pipe is:
Super Bee: Minimum 20mm (3/4") / maximum 25mm (1")
Falcon: " 25mm ( 1" ) / " 31mm ( 1 1/4")
Super Eagle " 25mm ( 1" ) / " 31mm ( 1 1/4")
Rhino " 30mm ( 1 1/4") / " 38mm ( 1 1/2")
Additionally, we are finding through testing using installed ByPass assemblies, if you leave the top half (half toward you) of the ByPass off, each turbines performance increases quite nicely as compared to a completely enclosed ByPass. Just FYI. . .
Best regards,
Eric Clapp
Jet Central Micro Turbines
Lifetime Warranty
Jet Artes Gulf Coast
Skymaster ARF PLUS
Best regards,
Eric Clapp
Lifetime Warranty
Skymaster ARF PLUS
Thanks Eric,
What is the cause of the increase with the top half of the by-pass off? More air (for the pipe), better cooling?
Is this unique for the Flash?
Hope you and your family have a Great New Year!
My Feedback: (10)
FL
I believe with the top or 1/2 of the bypass removed, the turbine simply gets more air. While max RPM settings with and without 1/2 of the bypass are the same, performance is very definately better. I have tested on the Flash, MB-339, Skymaster L-39 and Skymaster Hawk all with the same results. . .hope this helps.
Happy New Year to all. . .
Eric Clapp
Lifetime Warranty
Eric Clapp
Lifetime Warranty
Excellent tip Eric! Recently, I wasn't too impressed with the vertical authority of my Eagle powered Flash and accepted that it must be the weight at takeoff. After removing the top half of the by-pass, totally different animal. Unlimited vertical...the Eagle is a beast and has not failed me for 12 flights now! Never thought a poorly designed by-pass could kill the output of these turbines. Thanks again!
