Go Back  RCU Forums > RC Helicopters > Scale RC Helicopters
 Blade CP Pro AS350 >
Blade CP Pro AS350
Scale RC Helicopters Discuss scale helis, and modifications to pod and boom helis that make them scale.
Blade CP Pro AS350
Old 01-02-2008 | 09:22 PM
Default Blade CP Pro AS350
Here are a few shots of what I am working on for the winter.
Scaled for a CP Pro, ~14.25" from main rotor axis to rear rotor axis. I plan on building up with wood to make a plug, and using either some carbon fiber or fiberglass from work to lay up the shell.
Old 01-03-2008 | 08:06 PM
Default RE: Blade CP Pro AS350
update
Old 01-03-2008 | 09:19 PM
Only a little internal work to do to finish off the tail. Next I can start adding formers to frame the stucture of the plug.
Old 01-04-2008 | 01:58 AM
damn, nice job! don't forget the horizontal stab . What are you using as a model?
Old 01-04-2008 | 09:54 AM
Thanks lins, in the OP you can see one view of a three view drawing that I have constructed this model over.
Old 01-06-2008 | 01:31 PM
Hey, how about an EC130 B4? It's an AS350 basic frame, an EC120 windscreen with an extra window in the middle, and a fenstron. [8D]
Old 01-06-2008 | 07:47 PM
I would have to look it up, see if I can find sketches. I've got an MD500 that I want to do after this, as well as a Huey, and a Supercobra. Now that I thought about it, I should have started with the Cobra, more flat surfaces.
Old 01-08-2008 | 12:50 AM
More progress
Old 01-08-2008 | 12:53 AM
Damn, that is really good!
