JR 10X transmitter lights?
TX
RE: JR 10X transmitter lights?
Once indicates that the TX is on, and the other that an RF signal is being output. I *think* the power on is the left, and RF the right . . . you can confirm by powering up with no module inserted - the dark one is the RF indicator . . .
- Tim
- Tim
That is correct, the LED on the right indicates RF and is a true indication that RF is being generated. ie Detected, rectified and used to drive the LED.
If you use a 3rd party plug in module for 2.4 GHz, the LED will remain dark.
