Lifeboat: self righting test
This happened yesterday, Saturday 09/20/2008, in a lake we have in the province of Buenos Aires.
I built my Mersey class (well, not to scale) lifeboat, with self-righting capability...but that had to be proved:
http://www.youtube.com/watch?v=MLxzf1ydUaQ
The deck is attached to the hull with 1 nylon screw at the stern and a tip under the fore deck. Under it there's another water tight "deck". It even doesn't have any wiring exiting it, the on-off switch is a magnetic one (a reed relay), the lighting system is mounted in the cabin, completely separated from the hull. The antenna wire runs through a hose.
And of course it kept on running after the test!
http://www.youtube.com/watch?v=Me9L6nkLbZw
http://www.youtube.com/watch?v=A88EKhGLlmo
Here's a link to the building process, (still) in Spanish sorry, but easy to follow with plenty of pics.
http://www.camne.com.ar/presentandom...villaverde.htm
Regards
Robert
Regards
Robert
RE: Lefeboat: self righting test
Try this one see if its in english. http://translate.google.com/translat...llaverde%2ehtm
