Nitroplanes Yak-54 120
Has anybody bought and flown this plane yet? My son has the Nitroplanes Yak-54 50 size and it flies terrific. He had his early prob with the weak stab but once that was fixed, no probs at all. So I am enticed by the new 120 size, and sure am tempted to get it and put my OS 120 Surpass with pump into it. Any reports on this plane would be appreciated. I have seen a couple other guys ask about it, and no responses were received. Thanks. Jon
WA
RE: Nitroplanes Yak-54 120
I have this plane and have flown it quite a bit. The plane flys excellent. I have an os 120ax on it. I don't know if the 4 stroke will have the power that you will want. All up weight is 9lbs ready to fly. The only complaint is the wingtube is a little soft so I bent it on the third flight. I have since put a dowel through the wingtube and it hasn't had any other trouble.
Thanks basinbeater! I think the four stroke should work...I have one without the pump in a 9pound CG Ultimate and it has unlimited vertical. Glad to hear yours flies excellent. That is what I like to hear. Were you satisfied with the quality of construction? Anything you recommend that I watch out for? Thanks. Jon
