Midwest AT6 build
Old 04-10-2009 | 03:22 PM
Live Wire's Avatar
Default Midwest AT6 build
The big brown truck dropped of a couple boxes for me to work on. Just happened to be a AT6 that I am to build for RR24. The fuse has been started, so all I mainly have to do is build the rest of the plane. Will have Pic,s as soon as I get them down loaded.
All posts welcome as we can work together on this one .
Larry K
Started working on this bird April 9 2009 3PM DST
Old 04-10-2009 | 03:34 PM
Live Wire's Avatar
Default RE: Midwest AT6 build
Pic's
ID:	1177335   Click image for larger version
ID:	1177336   Click image for larger version
ID:	1177337   Click image for larger version
Old 04-10-2009 | 07:13 PM
RR24's Avatar
Looks Good Larry, you sure dont mess around, you already got alot done.
Wes
Old 04-10-2009 | 08:52 PM
Live Wire's Avatar
I just put the landing gear in the center and have just a little mods to do and it will be ready to sheet. You no I dumped the plans you had for the flaps[:@] There were a few peaces of wood missing no problem though going together real nice.
Larry
Old 04-10-2009 | 09:10 PM
RR24's Avatar
your building it, do it how you want
Wes
Old 04-11-2009 | 03:40 PM
Live Wire's Avatar
Ip date
This on is going to have flaps The gear has been installed in center and sheeting installed.
ID:	1177985   Click image for larger version
ID:	1177986   Click image for larger version
ID:	1177987   Click image for larger version
Old 04-11-2009 | 04:41 PM
My Feedback: (60)
One of the fiberglass companies (not sure which one) offers the wheel well area for the Midwest T-6 which is much more durable than the vac formed plastic supplied in the kit. A little bit of research should turn up the manufacturer if you're interested.
Old 04-11-2009 | 05:01 PM
ccostant's Avatar
My Feedback: (38)
It's Fiberglass Specialties if your interested. Just look in the cowl and accessories for kits section. It's a nice part.
http://www.fiberglassspecialtiesinc.com/catalog.htm
Old 04-11-2009 | 05:31 PM
Live Wire's Avatar
Wess just might want to go that way.
Larry
Old 04-11-2009 | 05:47 PM
RR24's Avatar
Larry i ordered one, it will be about 1 1/2 to 2 weeks before i can get it to you.
hope that will work
Thanks Wes
Old 04-11-2009 | 07:01 PM
Live Wire's Avatar
Wess
Shoud be no problem, Time to start watching glue dry Just wondering , do you have the air equipement tanks line and valve, and yes what was the size of that engine you have, Just thinking it might be wise to put the servos in the tail for the elevator. They will mount there real nice. One on each side!
Larry
Old 04-11-2009 | 08:17 PM
My Feedback: (60)
ORIGINAL: Live Wire
This thing generally requires substantial amounts of nose weight (understatement) and I would recommend putting everything as far forward as possible. I think that even those guys who are using a G-38 up front are still needing nose weight to balance. I would certainly recommend doing your homework before sticking anything aft of the CG that does not have to go there.
Chad Veich
Old 04-11-2009 | 08:59 PM
RR24's Avatar
Yes i have the tanks and lines, and i have a G-38 for it also.
Wes
Old 04-11-2009 | 11:12 PM
Live Wire's Avatar
ORIGINAL: Chad Veich
ORIGINAL: Live Wire
Chad Veich
Thanks for the reply. I plan on taking a lot of weight off the tail when I scale down those square tail serfices, That is why I make sure of what goes up front before I get to carried away with weight.
Larry
Old 04-12-2009 | 10:22 AM
I just finished my Texan restoration. Finished installing the radio gear and tuning the engine yesterday. Balance check shows that even with the heavy Quadra 35, it is tail heavy. Also using fixed landing gear. Do not have any weights now so will have to balance it later this week. Then it will be ready to fly.
Jim
ID:	1178550   Click image for larger version
ID:	1178551   Click image for larger version
ID:	1178552   Click image for larger version
ID:	1178553   Click image for larger version
Old 04-12-2009 | 10:38 AM
RR24's Avatar
Looking good Jim, i have been watching your rebuild for awhile
Wes
Old 04-14-2009 | 06:19 PM
Live Wire's Avatar
Wess
The fuse is skinned, and I just had to compare it with my Waco
ID:	1180408   Click image for larger version
ID:	1180409   Click image for larger version
ID:	1180410   Click image for larger version
ID:	1180411   Click image for larger version
Old 04-14-2009 | 06:26 PM
Live Wire's Avatar
Now back to the wings and tail feathers. Servo mounts and skin well be a snap since the fuse was like covering a Coke bottle. I never new that plane had so many curves
Larry K
Old 04-14-2009 | 07:41 PM
You'll like that plane......I have had mine for four years now. Flys with a 120 Saito engine.......looks like the real thing in the air.......need to fly it in for a landing.
Old 04-14-2009 | 08:14 PM
RR24's Avatar
Larry looks good, your making good time
Thanks again Wes
Old 04-14-2009 | 09:00 PM
Live Wire's Avatar
Wess
Thought you would like to see the tail feathers and how I am doing them. You can see the glue I startd useing. works great and sets up fast for joining sheets.
ID:	1180524   Click image for larger version
ID:	1180525   Click image for larger version
ID:	1180526   Click image for larger version
Old 04-14-2009 | 09:10 PM
Live Wire's Avatar
Where can a guy find close up shots of the control surfices. I must be looking the wrong place. All I can find is profile shots, or flying.
Larry K
Old 04-14-2009 | 09:49 PM
RR24's Avatar
http://www.photovault.com/Link/Milit.../T-6Texan.html
http://users.ids.net/~thompson/snj.html
Larry i didnt know if where looking for the reak thing or RC pic's, but i found this stuff dont know if it helps
Wes
Old 04-14-2009 | 10:24 PM
Live Wire's Avatar
Well I can build planes but this computer has got this old man runnig in circles. Finding just what i need is something else.
Looks like I do what I have to for the Robart hinge points. These guy's are prode of their Info.
Larry K
I had these sights and they do not have what I want. Looking for full scale hingeing and how they attach the gear doors. Don't know haw far you were planning on going with this bird bud it is a challenge
Old 04-16-2009 | 07:09 PM
Live Wire's Avatar
One of those day you dream about You can not believe what I got done.
ID:	1181615   Click image for larger version
ID:	1181616   Click image for larger version
ID:	1181617   Click image for larger version
