Newbie to Gas General Information
My Feedback: (198)
This thread is here as a FAQ or Starters Guide for newbies to gasoline powered engines. Please do not post regular chit-chat in this thread. It will be deleted.
Consider this a READ ONLY thread.
Rcpilot 04-16-09
There are so many threads with hundreds of the same questions and answers...maybe a few basic things in this thread would qualify as a "sticky" and RCU would help us who provide those answers to reduce duplications.
So... as a "newbie" to Gas. Some things in general that you must keep in Mind and Learn About Doing.
1. All tank and plumbing accessories must be "gas" rated. Dubro brown color stoppers are the "standard". Yellow Tygon is widely used. Clear tubing is crap. All fittings need to be "secured" over their attachment barbs. All smooth brass tubing needs some kind of bump, solder blob, or barb to keep Tygon on, as it swells in use. BEFORE it gets rigid and brittle with age. NORMAL.
1a. Klunks and filters.....gotta have 'em someplace. Klunks in the tanks that are like the little Walbro "felt clunks" in your weedeater work REALLY well. So do more exotic ceramic particle filters. Gotta have a klunk. Gas should be filtered in the jug, too, before it gets INTO your airplane. And yes, tanks only need two lines.... vent to atmosphere and line to carb. You can use a tee with a fuel dot to fill and drain the tank. It will work forever. You also can use three lines, but that gets a little more complicated. Use filters.
USE FILTERS.
1b. Pulse Lines - MANY gassers have a piece of tygon fuel line running from a fitting on the crankcase or intake adapter to an inlet pipe on one of the "sides" of the carb. This line is NOT for gas. It must not be kinked. It cannot have holes. If not hooked to the pulse line on the carb, the carb will not pump. Ever. When in doubt, call the manufacturer. Most of them ship their engines with the pulse lines already properly connected. Sometimes they even have manuals with pictures in them that MAY show this line and it's fittings.
2. Every engine with a Walbro or "clone" carb MUST HAVE it's Low and HIGH speed needles re-adjusted from factory settings to get GOOD performance. EVERY ENGINE!!!
2a. Walbro carbs (and other similar) have PUMPS. Rocking the prop back and forth or flipping it with fuel will PUMP the head full. Spark doesn't work under fluid. The tank can be a long way from the carb, and it's okay. As you rock the prop, watch the air bubble/fuel move up the line. If the bubble isn't moving....the pump isn't pumping. Get the pump wet inside somehow. Fact.
3. Breaking an engine in on the ground is generally not a real good idea. Use the manufacturer's recommended oil ratio for starters, get a couple tanks (or less) through the engine to make sure everything is okay, then go fly the damm thing so it will have SOME form of cooling air over it.
4. Spark plug cap fittings usually fit very tightly if they are the "push on" type, and you will have to push HARD. It's normal. If the plug cap isn't on correctly, it will not run right. EVER. And you'll get unreliable starting, running, and radio interference (all not-good things).
5. Prop drilling - if you have a jig, use it. If you don't, use the prop washer as a guide and try to get straight holes. ALWAYS balance a prop before using it.
6. Most carbs will require you to modify the throttle arm to be "user friendly" for our pushrod/ball link setups. Get over it. It's the way it is. Use a short servo arm to attach to the crappy little plate they supply on the throttle butterfly shaft. Use ball links and very rigid pushrod setups with GOOD servos.
7. Remove and toss the "stop screw" on the throttle arm plate, then unhook the little spring that pulls the butterfly closed, unless you want your throttle servo under constant load/tension. DO NOT REMOVE THE SPRING.
8. Electronic ignitions work wonderfully, if they are getting power. Use a reliable battery with the voltage rating and milliamp hour rating that the manufacturer recommends. WHY??? Because if you toast the ignition from incorrect battery usage - YOU WILL BUY THE REPLACEMENT. If they say nothing, go with a 4 cell 1100mah NiCad, or NimH, or a 5 cell system on a GOOD regulator. Not recommended for newbies. Get some experience with this area. Always use a switch, and setup throttle so you can kill it.
Generally speaking, there are "good" ignitions, and there are "cheap" ignitions, but not so much "Good and Cheap". Ya gets what ya pays for on this one!!!!
8a. Ignitions all have three chunks of wire. ONE, the spark plug lead, also contains the "ground", and must make contact with the outside of the plug hex (where your socket wrench grabs the plug). It can't have holes, or cracks, and should always be prevented from rubbing on ANYTHING. TWO - "Power", usually a "female" battery-type connector with a red and black or red and white wire/connector. This is where the "OUT" of your switch provides power to the ignition. NEVER get the red and other color mixed up ever!!! THREE - the "sensor pickup" - usually a black/white/red (or similar) wire that connects to the thing that is mounted up near the prop hub (on most engines). This is the "hall switch", and picks up the rotation of the prop hub by sensing a magnet when it rotates past the face of this switch. ALL three wires have to connect, and the polarity of these three wires can never be wrong, either. The igniton senses the magnet rotating past the switch on the hub/crankcase to figure out when to send the spark to the plug. It only "knows" when the magnet has passed it. ALL of these work the same way. Rotating the hub magnet past the hall sensor/switch means that the IGNITION **WILL FIRE THE PLUG** if it has power. Many people with injured fingers thought an igniton was OFF when it wasn't and found out by casual flicking of a "hot" prop. The ED department visit usually costs more than an engine. AVOID this, always. Treat a gasser with an ignition attached as if it is HOT, 100% of the time.
9. In general, a new carb will not pump if it has been dry for awhile. Period. Get some gas into the thing by normal "priming", close the choke, flip through a few times, ignition on, throttle at high idle. Engine pops starts, dies, open choke, flip till starts. RESTRAIN you AIRPLANE while doing this. ALWAYS.
10. These gassers need GAS. Not some other kind of make-believe fuel. If yours has ethanol, it will be okay. 95% of our engines will do just fine on regular unleaded 87 octane pump stuff. They also have to have OIL. Nearly all of these need about 30 or 32:1 ratios for their first starts. That's 4 oz to a gallon. Easy to remember. Won't hurt the engine. Use a good oil for 2 strokes. If in doubt, call the ENGINE seller about ratios and types. If they don't answer, THEN post on here.
Rcpilot 04-16-09
USE FILTERS.
RE: Newbie to Gas General Information
11. No Metal to metal from the servo to carb. Use nylon rod and sleeve.
12. Place the Rx as far as practable away from the CDI as possible.
13 - Whoo - black Friday - dont fly on this day.
Sorry - could not resist
My Feedback: (198)
14. If it isn't running right on the ground, it will NOT improve in the air. ADJUST IT!!! And do that ONLY after it is at it's "normal" operating temp.
15. More prop does not mean more power. It means more load, and generally that isn't a good thing. EVERY prop change on EVERY engine will need re-adjustment. PERIOD.
16. If someone helps you and things get worse with your engine - get a different helper. ALWAYS.
My Feedback: (198)
17. Mufflers - nearly all of them are NOT; they are exhaust cans with diverter outlet tubes. They are usually louder than you think. If you want quiet, you need a canister, period. Not necessarily for newbies.
18. Install muffers with no gasket, use a thin film of Permatex High Temp Permagasket on the face of the muffler flange. Put RED "permanent" or "high temp" Loctite on the screws, and tighten them. Tightly.
19. If you have to use a Pitts muffler, brace the canister part to the engine/firewall with a bracket or strap of some kind. Tighten the muffler to the engine exhaust THEN install the strap/canister attachment. Don't do it the other way.
20. Smoke is not for a newbie. If you must smoke, get help with it, as you've instantly doubled your plumbing complexity, tanks, added weight, electronics, etc. If you have to have it, post here on "How to Setup Smoke". It works great and looks like a million $$$ but most folks don't mess with the mess.
21. Spark plugs. These are not glow plugs. They need ignition sources. They have to be properly gapped. They should not be oily-looking, fouled, or have shiny metal flakes on the porcelain. ANY of these things are symptoms that something else is wrong.
22. If your engine doesn't "take throttle" (hesitates), the low end is probably lean. If it "takes throttle", but bogs down, coughs, sputters, etc. it is low end RICH. NO doubt about these. Properly-adjusted gasser carbs operate very well. Poorly adjusted ones will make you insane.
23. If you have been flipping until your arm is ready to fall off.....go back to the first post on this thread. SOMETHING ain't right. All of these engines need air, gas, compression, and ignition. Given all of them in the proper portion and time, these engines ALWAYS start. If they do not....SOMETHING IS NOT RIGHT!!!!!! Don't post on RCU about what to do.....figure out what's missing from the thing. If it's all there, THEN post for help. We will be happy to help....those who try.
My Feedback: (24)
GA
Great post Bob but I have to lightly disagree with 1A, If a two line system is used make sure the tank is not lower than the fuel er you use, If it is the fuel will run out of the line back into the tank and then you have to pump the fuel back to the carb and there will be air in the line. Making the first start after fueling a little harder.
Milton
Milton
My Feedback: (198)
ORIGINAL: RC Extreme power
Milton
Milton
Excellent posts Bob, makes me wish that I had found something like this having so much of the good stuff in one place when I was starting out in gas.
Karol
The following is added by the moderator . . . .
Karol
Original:Antique
CARBURETOR 101[>:]....All Walbro and Tillotson carbs were originally made for something else, not a model airplane...The other users have a trigger to operate the throttle, hence the spring....All Walbros and Tillotsons have a clip or some means to keeo the shaft tight against one end...'
The spring has two functions, to return the throttle to idle and to keep the shaft against the clip or whatever centers is..
When a carb is wide open the disc does not completly fit against both ends of the hole in the carb, the venturi...
The spring's other function is to keep tension on the shaft to hold it against the end and not let it rattle around in the hole..
A carb with no meas to keep the dixc in the center will eventually get worn on one or the other or both ends to a point when the throtte is completely closed there is enough space on the ends to let fuel through and the idle will be too high...
I have been working on these things for at least 25 years and have seen quite a few worn carbs, both on the ends of the disc and both sides of the body wher the disc has been vitrating against it...
Take the spring off if you liike, if you fly long enough you will find that your idle will be too high and the engine can not be cut off with the throttle....PERIOD[>:] If this explanation offends anyone's tender ego, so be it, get over it, it is the truth...
Tillotson carbs have a brass washer and clip...And a spring.
Some Walbros have a clip on both sides, and a spring...
Walbro WTA6 G38 carbs have a spring on one side and a wider clip on the other end screwed into the carb body to keep the shaft centered...
Glow carbs generally have a rotaty barrel with a groove in one end. sometimes straight, sometimes spiral...there is a screw in the carb body with the end turned down to fit into the groove...Some have an internal spring....
My Feedback: (198)
Thank you! Hope it is helpful. Continuing...
24. Gassers vibrate. Period. Firewalls must be STRONG, and pinning around their circumference with wood dowels or epoxy/nails is a good practice. Pulling the engine box off an ARF is easier to do than you think.
25. Your engine will probably require "standoffs". Measure your ARF from intended prop spinner backplate to firewall. Deduct the overall "mounting length" of your engine, plus 1/8". Whatever is left is the "standoff". You can buy metal ones, or make your own out of hardwood dowels, whatever. BUT - they have to mount real solid-like. Find sources of long #10-32 hex head bolts, split washers, flat washers, fender washers and nylon-insert Locking nuts. USE them. It is a BAD plan to have an engine come loose.
26. Allow "exit area". You cannot avoid it. You either make holes to let LOTS of air out of your cowling/nose, or you cook your engine. Period. If you are able to do it, direct air by dams or ducting directly over the fins of the engine, THEN to the "big exit area".
If you hover, or do strenuous 3D....skip this step and you'll cook the motor, probably seizing it up at a low-altitude hover by overheating, thereby crashing your airplane ALSO.
27. Props - the most important accessory for your engine. Bad props give sucky performance, break easily, or disappoint you in their performance. Any good prop of the manufacturers rated size will make you a happy gasser.
27a. Prop Balancing - probably an oft-ignored and vitally-important "thing" for gasser guys. A good balancer is essential. A bad balancer is a waste of money. I prefer the Dubro Spin balancer....very sensitive. Blades are balanced by lightly spraying the back of the blade with clear spray lacquer- lightly...until blades balance. If blades are balanced, but moves anyway, check the hub. Put the prop on the balancer with blade vertical. Release blade. Watch top blade....if it falls LEFT (as you're looking at it) then the RIGHT hub needs weight, and vice versa. Weight on the hub is the curly velcro, ca'd in place, a few drops of thick ca, then kicker. Recheck balance. Keep at it until the prop remains motionless wherever you position it on the balancer. THAT is perfect balance. Takes about a half hour on a 22", more on bigger. DO IT.
My Feedback: (198)
Already asked....we'll wait and see.
28. RPM readings. Nearly meaningless for one user to compare to another user. Even if using the same prop. Carbs are very sensitive and being off the sweet spot by 1/16th turn on the H needle can make a big difference in tach readings. Plus, most tachs are semi accurate, part of the time, and light/angle sensitive all of the time. Unless you know me, and how I I tune, my altitude, air density, oil mix ratio, type of oil, and heat temperature....my peak rpm is of no consequence to you except for "ball park", and it's a helluva big park. Most 50cc gassers and above should be somewhere around 7000 with the "stated" prop from the manufacturer. Larger displacement, lower peak rpm. That's how it goes.
29. Freqently check your ignition battery voltage. Under load, if possible. An ignition battery that is losing it's guts will create bizarre unreliable and misfiring engines.
30. If your engine was fine yesterday, and today it's NFG, then *something* changed. Find what changed, and fix it. Don't jump to conclusions and speculate. Work through the systems. Start at the tank, work through the plumbing. Start at the battery, work through to the plug, start at the servo, work through to the butterfly. Only a VERY few, and "special" engines are actually sold with Gremlins built into them. Usually they have already been owned by someone who couldn't find and kill the gremlin, so you got it. Think of a finicky motor as a PC virus....there is a solution....you just have to find it.
ORIGINAL: Bob Pastorello
30. If your engine was fine yesterday, and today it's NFG, then *something* changed. Find what changed, and fix it. Don't jump to conclusions and speculate....
Last week, I came to the strip, put the plane out, put on the wings, charged everything up, put the canopy, fueled it up, choke, flip, flip, flip, nothing.. opened the choke, flip,flip,flip, flip,... unusual POP! from the manifold.. hmm.. it never done that before?
So, removed the spark plug, wettish.. I let it dry and start over. With choke, flip flip flip, POP! again with an unusual sound as if the timing is off.. removed the cowling, inspected everything.
I suspected the properly padded ignition, so I removed the plug, put a new plug in it outside of the engine - to see if its firing. It did seem normal. spark visible..
So here I am, with perfectly fine engine thats got fuel, oxygen and fire but no go.. now thats not possible..
needles were adjusted properly, no junk anywhere, ignition battery, switch and cables are OK...
After 5 hours of inspection, trial and fail, I came back to my first suspect: the ignition module..
Swapped out my ignition module from a frieds DL50 - no choke, flip ONCE and VRRRRRRRAMM!! Running like a clock..
Put my ignition on my friends DL50; flip, flip, flip, flip...... unusual POP!.. no go.. There it was.. a mysteriously gone bad ignition module that decided not to work properly anymore without a single reason..
My Feedback: (24)
GA
ORIGINAL: liquid_TR
That is exactly what happened to my DL50 last weekend.. It's a new engine and was working perfectly the week before.
A couple of things that have happened to me, now I am talking about the RCXell Ignitions.
I had a ignition that I used to test run engines, Mounted a engine hooked all up and engine would not start, now i keep a couple of 4.8 volts batteries for testing also, Got another battery and engine still would not start.
I also have a ignition tester made by CH that will simulate a engine running about 4,000 RPM, Installed it and the ignition was working but noticed that it seemed it was not sparking a loud as I thought it should, got another ignition and and put the tester on it and the spark was louder and cranked the engine with no problems, Just shows that just because there is spark does not mean all is well.
Next
Had a engines sold to a customer from a local club that had problems, Said after about 2 min of flight the engine would just stop running, Sent him another ignition and after about 2 min of flight the engine stopped running and would not start again.
So i made a trip to there club, After a little frustration I found he was using a 3 cell lipo with a standard Duralite regulator and when we tested the out put voltage it was putting out 6.7 volts and was cooking the ignitions.
You just never know what will come along and bite in the beee.[:@]
Milton
My Feedback: (198)
For those following this thread....as new things occur to me, I'm going back and editing my previous posts where the item logically fits.
I'll add new posts as new items occur.
31. When you have a new engine....buy a new (correct) spark plug. And as soon as you can afford it a Spare Ignition, and a Hall Sensor/switch. Spare carb if you aren't a "carb tweaker". Carb rebuild kit whether you are or are not. Buy replacement prop bolts, and be sure to use split and flat washers so the prop washer doesn't get all boogered up. Many manufacturers don't know about this yet, so they don't include screws long enough for thick hubs and spinner backplates, much less the split and flat washer. It is worth investing in.
32. Buy extra metric screws and ball drivers. NEVER trick yourself into believing that a 10-32 is the same as a 5mm. They ain't.
My Feedback: (82)
33. ALWAYS provide for some form of emergency engine/ignition cutoff. At a minimum, install an external switch that cuts off power to the ignition. Better yet, add to that an internal ignition cutoff, that is connected to a spare channel on your radio. Optical remote cutoff modules from SmartFly or other providers, work really well. Make sure the assigned switch is out of the way, so you do not hit that switch accidently while flying.
34. Tygon tubing, of the type mostly used for gas engine in model airplanes, degrades over time. Check the tubing on any airplane you have acquired, especially at the ends. The piece of tubing inside the tank that is attached to the clunk and dipped in fuel, will likely get hard in a year, loose its flexibility and could be the source of fuel draw issues if not checked.
Hi Bob and others who have contributed to this topic, i hope it is ok i will be pulling some of this thread and posting for our club web-site, as there is an influx of large gas engines in our club. (WRCS in Australia)
Most club members have a good idea about glow motors but gas is new and causing some confusion, of course there is the usual bunch of guys who know it all but when put into service make things worse so there is a steep learning curve happening at the moment and these posts will help to untie the knots.
Regards Dave.
Regards Dave.
ORIGINAL: dubs1946
Regards Dave.
Regards Dave.
Karol
My Feedback: (198)
I was struggling with this post. My evil twin won!
35. OIL - It is vital that you protect a gasser with the RIGHT kind of internal oil film for operation. Too little oil and it will die a quick and horrible death. Too much oil, and you plugs and airplane covering will look "ugly". It is never a good idea to use an oil that intentionally introduces abrasives to "wear in" an engine. Let a proper amount of good oil do that during FLYING !!!
Everyone has their preferences; some are based on experience, some on knowledge, and even fewer on BOTH. Ask the person with BOTH what they recommend.
ALWAYS pay attention to what the company that is providing WARRANTY on your engine says about oil. Do it "their way", or be prepared to fix the engine yourself for ANYTHING even remotely-oil-related.
My Feedback: (198)
36. KILL SYSTEMS - Gassers, because of their power (and usually size of airplane) **SHOULD** have some sort of a "kill device" either mechanical, or electrical. In general, most folks agree that a transmitter-operated kill switch is a good safety device. If airborne, with a typical large tank, your throttle servo fails or disconnects, you either land hot and break something, or fly around risking killing batteries. If you have a switch to flip that chokes the engine, or removes power from the ignition, YOU can decide when to land - safely.
a. Choke Servo - this involves hooking up a choke servo to an extra channel, and assigning to a switch or lever on the TX that closes the choke when you actuate it. Overly-rich, with air cutoff, the engine will die quickly. Pros and cons to this system.
b. Electronic Kill Device - this involves an electronic switch that is operated by a spare RX channel, activated by the TX that cuts off power to the ignition module. These are nearly always installed "after" the on-board separate ignition switch, and "before" the module in the power lead. Usually optically-coupled electronic switches, they don't induce any harmful interference when properly installed. Lots of these available. If going this way, ask around your area, or on RCU to help make your decision.
Whatever you do, please ALWAYS consider the safety benefit of being able to shut off your gasser when YOU want to. It is a vital element of overall RC safety, IMO.
My Feedback: (63)
Bob,
I have a question. What is the proper way to drill and mount a propeller. On my glow engines I always position the propeller for easy flipping ie engine just coming into compression and the prop at about 3 oclock. The answer should be obvious, but to me it isn't. Two of my engines do not have holes for extra bolts, the other two have three holes for bolts. Joe
My Feedback: (198)
ORIGINAL: flyalot
Bob,
Bob,
If you have a drill jig for the engine, and a drill press, align the marks with blades, mark through the holes of the washer. Install the jig from the back side of the prop aligning the holes. Drill.
If you do not have a drill jig, mark the holes on the back of the hub using the washer, then drill using it as a guide (if you have a drill press).
If no drill press, I carefully mark holes on both front and rear for drilling, and try to drill half way through. Turn prop over, drill remaining part of the holes. Rebalance after drilling.
AZ
I was wondering if it is absolutely needed to drill multiple holes requiring the aide of a drill jig or can someone just use the single hub bolt to hold the prop on? I just purchased a 26cc and cant find anywhere if there is a need to do so. I know that a gentleman at the club I started flying at years ago had a single bolt to hold the prop on but, now that I'm dipping into gas engines I would like to know if he was just lucky or what. I knew he flew the ever lovin S*&^ out of it and never had a problem.
Stangevil29
Stangevil29
