Go Back  RCU Forums > TEAM RCU > Team RCU - Don Szczur
 Setup for DX-7 and throttle Curve >
Team RCU - Don Szczur Ask your questions directly to Don Szczur, proffesional pattern pilot
Old 06-03-2009 | 08:59 PM
Don Szczur's Avatar
Default Setup for DX-7 and throttle Curve
AIrcraft flight testing setups for an off season practice plane.
Input for Spektrum DX7 setup to provide a more linear throttle response curve. SInce the DX7 does not have a throttle curve function this is what I did: Throttle to throttle mix, with + 40 percent rate for high end, offset of -42 percent. Iput this on the gear switch so it can be turned off and on to test the changes. When you go to the servo movement screen, the throttle moves pretty close up to half throttle, but the offset mix accelerates the throttle so that at about 5/8 stick it gives about 3/4 throttle, and at 7/8 stick it gives it full throttle. This gives a lot more of a linear feel around the upper throttle movement during pattern maneuvers. Motor is Eflight 60, speed controler is Castle 85 amp. Airplane is Angel .50. See pictures for interest.
ID:	1211554   Click image for larger version
ID:	1211555   Click image for larger version
ID:	1211556   Click image for larger version
ID:	1211557   Click image for larger version
ID:	1211558   Click image for larger version
ID:	1211559   Click image for larger version
ID:	1211560   Click image for larger version
Old 11-01-2009 | 12:29 PM
My Feedback: (9)
Default RE: Setup for DX-7 and throttle Curve
interesting. I´ll give it a try with my gassers...
Old 11-29-2009 | 03:41 PM
From: Bishop\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'\'s Stortford,
Mmm. Perhaps you should have gone and got a Futaba . . .
