Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
Electric ZN Line Xigris C2 Build Thread
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 09-10-2010, 08:59 AM
  #276
najary
najary's Avatar
Default RE: Electric ZN Line Xigris C2 Build Thread
More
ID:	1498335   Click image for larger version
ID:	1498336   Click image for larger version
Old 09-10-2010, 09:04 AM
  #277
najary
najary's Avatar
Step 14 = Preparations before spraying clear coat.
ID:	1498340   Click image for larger version
ID:	1498341   Click image for larger version
ID:	1498342   Click image for larger version
ID:	1498343   Click image for larger version
ID:	1498344   Click image for larger version
ID:	1498345   Click image for larger version
Old 09-14-2010, 08:58 AM
  #278
najary
najary's Avatar
Step 15 = Preparing the clear coat.
70% thinning.
Adding few drops of metallic silver pigment gives the lacquer sparkling effect.
ID:	1500714   Click image for larger version
ID:	1500715   Click image for larger version
ID:	1500716   Click image for larger version
Old 09-14-2010, 09:01 AM
  #279
najary
najary's Avatar
Step 16 = Spraying the clear coat.
ID:	1500727   Click image for larger version
ID:	1500728   Click image for larger version
ID:	1500729   Click image for larger version
ID:	1500730   Click image for larger version
ID:	1500731   Click image for larger version
ID:	1500732   Click image for larger version
ID:	1500733   Click image for larger version
Old 09-14-2010, 09:10 AM
  #280
najary
najary's Avatar
Weights after step 16 = 1,276 gram
Total weight of the finish process = 1,276-1,131(post 229) = 145 gram.
Step 16 = 47 gram (145-98)
ID:	1500737   Click image for larger version
Old 09-15-2010, 11:47 AM
  #281
najary
najary's Avatar
As a result of what I saw at the European Championship in Austria, I decided to invest some of grams I saved in the building process in changing the motor from Hacker XL 14 to the new Hacher Q80.
The total weight with the Hacker XL 14 is 1,488 gram (513+929+46)
ID:	1501281   Click image for larger version
ID:	1501282   Click image for larger version
ID:	1501283   Click image for larger version
Old 09-15-2010, 11:51 AM
  #282
najary
najary's Avatar
More
ID:	1501287   Click image for larger version
ID:	1501288   Click image for larger version
ID:	1501289   Click image for larger version
ID:	1501290   Click image for larger version
ID:	1501291   Click image for larger version
ID:	1501292   Click image for larger version
Old 09-15-2010, 11:54 AM
  #283
najary
najary's Avatar
More
ID:	1501294   Click image for larger version
ID:	1501295   Click image for larger version
ID:	1501296   Click image for larger version
ID:	1501297   Click image for larger version
ID:	1501298   Click image for larger version
ID:	1501299   Click image for larger version
ID:	1501300   Click image for larger version
Old 09-15-2010, 11:59 AM
  #284
rcpattern
My Feedback: (45)
Simply stunning. Great work!!!
Arch
Old 09-15-2010, 12:02 PM
  #285
najary
najary's Avatar
The total weight addition of changing the motor is 98.5 gram (628+9.5+932+17 post 300 - 1,488 post 281).
ID:	1501306   Click image for larger version
ID:	1501307   Click image for larger version
Old 09-15-2010, 02:02 PM
  #286
Ricardo M.
Najary, amazing work. I really like your color scheme, very Japaneese. One question, why do you choose the Q80 over the Q60 when the Q60 is lighter ?
Old 09-15-2010, 04:00 PM
  #287
cdodom
cdodom's Avatar
its obvious that the Q80 looks cooler.
Great work!!! I can't wait to see how the rest of the plane will be setup. It looks like the motor and ESC will not have any trouble being cooled.
Old 09-15-2010, 10:48 PM
  #288
flyboy91
Najary,
Quick question, how thick is the carbon plate that you mounted the Q80 on? It looks to be about 2mm but I wasnt sure. Thanks for your awesome work on these planes its amazing to see them come together.
Andrew
Old 09-16-2010, 02:24 PM
  #289
najary
najary's Avatar
ORIGINAL: flyboy91
Najary,
Andrew
Hi Andrew,
The carbon plate is 1.6mm thick.
Best regards,
Isaac Najary
Old 09-16-2010, 02:57 PM
  #290
najary
najary's Avatar
ORIGINAL: Ricardo M.
Hi Ricardo,
1. I like the concept of the Q80, The force that is creating between the magnets and the electric coils has more moment on the motor shaft due big diameter of the motor, that's why I think it is more efficient than the Q60.
2. The Q80 runs colder than the Q60 (I don't like open spinners).
3. The weight difference between the Q80 and the Q60 is not so big if you take in consideration the need of the back mount of the Q60,(I don't think that the Q80 needs back support).
Best regards,
Isaac Najary
Old 09-16-2010, 03:17 PM
  #291
Mastertech
My Feedback: (31)
Mastertech's Avatar
Najary,
Your craftsmanship is superb! Simply amazing build thread.
Old 09-17-2010, 08:25 AM
  #292
Mastertech
My Feedback: (31)
Mastertech's Avatar
Najary,
Do you plan on adding a rear support to the motor?
Old 09-17-2010, 10:36 AM
  #293
najary
najary's Avatar
ORIGINAL: Mastertech
Najary,
No, see post 290.
Best regards,
Isaac Najary
Old 09-19-2010, 03:35 PM
  #294
Buka
Is the nose rigid enough to withstand the torque of the q80 ?
A friend of mine switched to a Q80 on a plane which was intially designed for a C50, the torque was so much greater that the motor twiested the entire nose
of the model.
would hate to see same happen to your superb plane, so pls take this experience into consideration.
Alex
Old 09-20-2010, 01:27 AM
  #295
najary
najary's Avatar
ORIGINAL: Buka
of the model.
Alex
Alex, you got me, I had some thoughts about the nose rigid, and expressly what will happen if the prop accidently hit the ground?
In spite of those thoughts and although I don't have weight problem, I decided to take the risk and not reinforce the nose.
Now, after you tolled me about your friends incident, I am seriously reconsider to reinforce the nose.
Alex, can you tell me more details about your friends incident?
I am inviting all you fellows to give me your feedbacks about the subject and ideas how to reinforce the nose.
Thanks in advance,
Isaac Najary
Old 09-20-2010, 04:00 PM
  #296
OhD
I recommend the rear support. It looks very easy to do and can be very light weight. Kris F flew one at Hollister this past weekend and maybe he will jump in and describe his rear support.
Jim
Old 09-22-2010, 07:15 AM
  #297
najary
najary's Avatar
Deleted
Old 09-22-2010, 09:06 AM
  #298
dinoslmn
Hi,
Any source in Israel for Gorilla Glue ?
Thank,
Old 09-22-2010, 09:47 AM
  #299
najary
najary's Avatar
ORIGINAL: dinoslmn
Hi,
Thank,
Here:
http://tecnik.co.il/index.asp
Best regards,
Isaac Najary
Old 09-22-2010, 09:48 AM
  #300
najary
najary's Avatar
Reinforcing the nose = 17 gram (1,460-1,443)
ID:	1505209   Click image for larger version
ID:	1505210   Click image for larger version
ID:	1505211   Click image for larger version
