Electric ZN Line Xigris C2 Build Thread
#181
RE: Electric ZN Line Xigris C2 Build Thread
ORIGINAL: najary
Hi Verne,
Thank you for the advice, I am going to implement it.
Best regards,
Isaac Najary
ORIGINAL: VerneK
Covering a balsa surface with liquid anything adds weight. On something as large as a wing, the amount would be significant. However, I do use Balsarite on the cabosil and resin gap filler between the root rib and fuselage because monocote won't stick to the resin. It's typically a very narrow strip and I just use an artist's brush to cover it with balsarite. Hope this helps. BTW, your build articles are great!
Verne Koester
Verne Koester
ORIGINAL: najary
Hi all,
Someone recommended me to use Coverite Balsarite before covering the wings with Monokote.
I would like to have some pros and cons opinions / thoughts.
Thanks in advance,
Isaac Najary
Hi all,
Thanks in advance,
Isaac Najary
Best regards,
Isaac Najary
#183
hi,
Last week, i finished a Xigris C2 for a friend...
Here some pictures - -> lietz-creation.skyrock.com/
Lietz
Lietz
#184
ORIGINAL: lietz creation
hi,
Lietz
hi,
Lietz
Very nice work over there.
Isaac Najary
#191
FL
Thanks for your builds Najary. I have enjoyed both of them.
I can not tell from the pictures how you get your overlaps. Could you describe how.
Thanks, Preston
Thanks, Preston
#193
ORIGINAL: preston blake
Thanks, Preston
Thanks, Preston
Take a look at post 188, in pic no. 4 I cut the shape with 3mm overlaping, in pic no. 5 you can see at the trailing edge the overlaping.
I hope that answer you question.
Best regards,
Isaac Najary
#194
Isaac: Could you briefly go over the procedure you utilize to apply your individual covering pieces with your covering iron. I assume you do not attempt to stretch individual pieces as they're being applied, correct?
Mike
Mike
#195
MI
I agree. I can't imagine trying to tack and iron down that large red monocote section with areas cut out without getting wrinkles. Impressive!!!
Verne Koester
Verne Koester
ORIGINAL: FLYERSG
Mike
Mike
#196
ORIGINAL: FLYERSG
Mike
Mike
I do stretch individual pieces as they're being applied.
Here is where I learned almost all the covering techniques, I think this DVD is a must for anyone who is going to cover a plane.
http://www3.towerhobbies.com/cgi-bin...&I=LXKSB4&P=SM
Best regards,
Isaac Najary
#200
ORIGINAL: nonstoprc
Just wonder if some computer program is used to design and visualize the pattern.
No computer program was used,
I copied the patterns from pictures in the internet and draw them on Bristol paper with a pencil and an eraser.
Best regards,
Isaac Najary
