BAD SELLER WARNING - AIR POWER TECHNOLOGY
hello,
<div><span style="background-color: rgb(230, 236, 249); color: rgb(0, 0, 0);" title="">Let me introduce myself quickly, I am a French RC-pilot,I wish to state that I do not speak English and I used a translator to go of my anger.
</span><span title="">I run into this forum to warn you and to go back to my experience of a certain vendor engine of your country!
<span style="background-color: rgb(230, 236, 249); color: rgb(0, 0, 0);" title="">the one that called AIR POWER TECHNOLOGY, the website is: http://airpowertechnologies.net/
</span><span title="">we decide to head to dealer because we build a patrol across spitifire third.</span><span title="">a link from the French forum with photos:
</span><span title="">http://www.modelisme.com/forum/aero-...lle-1-3-a.html
<span style="background-color: rgb(230, 236, 249); color: rgb(0, 0, 0);" title="">but the problem is not with planes but the engines that we buy from that seller, we chose two inline engines 11.6 (200 cc).
</span><span title="">upon receipt, I realized that the machine was not clean, ie the admission of the carburetor housing is handmade!
</span><span title="">the first rounds of helices, the first engines (mine) has just turned 2 hours and I had a gap in the linkage of over 2mm.
<span title="">impossible to continue, so I decide to look at the problem, but said the details had this seller telling me that the warranty would not work.</span><span style="background-color: rgb(255, 255, 255);" title="">I agree but this is not normal that a loose engines quickly!
</span><span style="background-color: rgb(255, 255, 255);" title="">I decided to wait until my friend passed out on his own, whether I should return mine.
</span><span style="background-color: rgb(255, 255, 255);" title="">and surprise, the second engine failure after 20 minutes of walking (not the propeller), then for not having a problem with the vendor we choose not to touch the engine.
</span><span style="background-color: rgb(255, 255, 255);" title="">after contact with this one, to offer him a refund of the full amount.
</span><span title="">the vendor decide not to respond and leaving me with $ 3,740 for two engines dead ....
First I decide to do the right thing for me seller no longer sell in France, and I walk towards you so that you will be warned, because it is a pity that in our passion there is scammers.
<span title="">I am enclosing two photos of my engines, connecting rod / piston:
<div><div><div></div></div><div>http://yfrog.com/1smoteur2j</div><div></div></div></span><span style="background-color: rgb(255, 255, 255);" title="">and connecting rod / crankshaft
</span>
http://yfrog.com/5mmoteur4j
</span>
</span></span></span></div><div>I hope it will react the seller can reasonably
thank you for advance
</div><div><span title=""><span title="">
</span>
</span></div>
</span>
</span>
</span>
</span></div>
cher Monsieur , la première image n'est pas visible, il ya un problème sur le site
En outre, je pense que vous devriez contacter le vendeur et expliquer oralement Ã* la situation que c'est beaucoup d'argent ici
J'espère que cela vous amène Ã* un accord
Bonne chance
Bonne chance
My Feedback: (16)
ORIGINAL: gadix
En outre, je pense que vous devriez contacter le vendeur et expliquer oralement à la situation que c'est beaucoup d'argent ici
J'espère que cela vous amène à un accord
Bonne chance
Bonne chance
Dear Sir,
The first picture is not visible, it is a problem on the site.
In addition, I think that you should contact the salesman and explain your position verbally that this is a lot of
money.
I HOPE that brings you to an agreement.
Good luck
(The first picture seems to show up OK for me?)
I have 3 engines here from the same company...4.2 single, a big twin, and a small single...None are useable..
Also a brand new crankcase for the big twin with a crank so far out that the 2 case halves wiggle up and down when the crank is rotated..The case has never been assembled with cylinders, the crank turns too tight when the case halves are bolted together...The crank can't be straightened, all the joints are welded...
The bearing bore in the 4.2 is .015 higher in one half, so the case couldn;t be tightened..The fix was grinding the rear crank extension by hand so it was undersize enough..There is no fix on this one, it would take a rebore and sleeve in one case half and a new crank that actually fits into the rear bearing tight enough to not slop around when the engine is running....
I can prove all this, I HAVE the cases in my shop...and another 3.2 with the bottom big end bearing out when the pressed in drawn cup bearing came apart....
I spent most of a day getting one of the smaller ones to run, don't know how long it lasted.....[&:]
ORIGINAL: w8ye
money.
money.
Here are the photos for anyone not able to see the links provided by the OP
For this sort of $$$, looks pretty grubby
<span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span style="background-color: rgb(255, 255, 255); ">yes these motors are very bad qualities.
</span><span style="background-color: rgb(255, 255, 255); ">tonight I contact the seller to put pressure, pointing to the website of the forum. </span><span style="background-color: rgb(255, 255, 255); ">I think he should react in any way is the best solution for him because his business is in jeopardy.
</span><span style="background-color: rgb(255, 255, 255); ">I even think that his company does not make a fortune ...</span></span><div><span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span style="background-color: rgb(255, 255, 255); ">
</span></span></div><div><span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span style="background-color: rgb(255, 255, 255); "><span style="line-height: 25px; font-size: 19px; ">there are no feedback in the world, I wanted to trust him but it was not a good idea.</span></span></span></div><div><span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span style="background-color: rgb(255, 255, 255); "><span style="line-height: 25px; font-size: 19px; ">
</span></span></span></div><div><span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span style="background-color: rgb(255, 255, 255); "><span style="line-height: 25px; font-size: 19px; ">thank you, I'm going to bed because it's time in France</span></span></span></div><div><span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span style="background-color: rgb(255, 255, 255); "><span style="line-height: 25px; font-size: 19px; ">
</span></span></span></div><div><span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span style="background-color: rgb(255, 255, 255); "><span style="line-height: 25px; font-size: 19px; ">@+aurel</span></span></span></div>
The parts look familiarly "xx" to me, including the lack of spacers on the piston pin/bearing assy, and the web rubbing in the crankcase. Reason for me to stop coöperating with the guy who tricked me into buying prototypes.
The first picture shows the engine as-is, the second picture shows the bearing retaining rings that keeps the rollers central on the piston pin. Without it, the bearing can move one way, and the rod the other. The rod mid position was taken care of by adjusting the crank in the crankcase, which also was not done by the manufacturer.
Thetwin of the OP looks likea high dollar engine, made of 25 dollar engine parts and some CNC work thrown in, without doing what it takes.
I found this.
<div style="display: block"><font color="#a80717" size="3">Air Power Technologies Service Policies
</font>
* Special international invoicing, shipping, and handling available upon customer's request.
* Return merchandise will be limited to thirty (30) days from the date of purchase with a 15%
restocking charge.
* All Air Power Technologies engines will be shipped U.S. Postal Priority Mail with Delivery
Confirmation
* International shipping is by U.S. Mail</div><hr />You may get your money back except for 15% restocking fees.<hr />You may also needto get help from a small claims court...
</font>
restocking charge.
Confirmation
TX
As an American, I personally appologize for this kind of behavior. This is unacceptable in the US as it is anywhere in the world. It is now in RCUniverse and will be passed on and around.
Cheers,
Chip
Cheers,
Chip
Unfortunately, these sort of business practices are an International phenomenon.
There are companies that push out products like this, especially for export because they are aware of the difficulties involved in seeking justice from one country to another
Hate to say it, but this has been going on for about 15 years, Never could understand how they have been around as long as they have, If there are any old timer Joe Nall people reading this, This is the company that used to have the big display that rotated the different engines on a big round wheel so they could run them for customers, I guess the ones they where running for show were hand picked.
I got burned to about 9 years ago, bought a used new in the box one that would never run, was so tight you could hardly turn it over with the plug out, There response to me was, run it it will losen up. LOL
The sad part is they know the engines are no good when they sell them.
thats why you need to be a smart shopper, do your homework before dropping several thousand on an unkown engine brand or ljunk engines.....
"homework" "research "aka browse RCU...
More data
<font color="#a80717">Air Power Technologies, LLC
1621 Liberty Ridge Road
Concord, NC 28025
Phone/Fax: (704) 788-9042
I looked up this address on google earth...could see the place clear...white vehical in yard. It is North & east of Concord. Also found a RC field near there on AMA web-search. The club has a phone number to call. Maybe they could fill in some gaps! That is it for now!...................</font>
Concord, NC 28025
Wasn't that long ago I received an engine from another source that has a bearing gap on the wrist pin worse than the one in the picture. Never did run the engine. Told the manufacturer, who sent me another cylinder to handle some other problems, but never did hear of the fix for the rod/piston/bearing fit. Needless to say I have not made many recommendations for buying anything in the company line up.
Hope the OP gets some kind of positive response from the seller, although I fear it will be otherwise.
<span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span>I hope that efforts will make a difference.
</span><span style="background-color: rgb(230, 236, 249); color: rgb(0, 0, 0); ">captinjohn our friend wants to help me that Charles minton (boss of air power technology)
</span><span>me back the money owed!
</span><span>with reference to these drivers of bad qualities.
</span><span>namely that the crankshaft is not a party, but each entry rod, the crankshaft is welded, quite deplorable!!
</span><span>meanwhile I am sending you a picture of my spitfire, without engines lol.
<div>
spit with my:
http://yfrog.com/jqalim1242j
http://yfrog.com/izalim1235j</div><div>
I am in the process of mounting a flat-twin engine has (275cc Limbach).</div></span></span><div><span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span>
</span><span>thank you for sharing my trouble was.
</span><span>@ + Aurel</span></span></div>
<div>
spit with my:
Sometimes you can recover $$$ if you paid for the engine you got through a credit card company. Not always! Woth a try...if you bought it with a credit card. Pay Pal...I do not know for sure! Capt,n
Aurelian: I called the Guy and we Talked. He said you bought 2 engines Both was 196cc Twins. He said he would fix them & ship them back to you. He said the repair was easy. He also said he would pay the shipping cost back to you. <hr />Another option...If you could take photos of all the parts you need to take apart engine...we here on RCU could help you fix the engines. We like to help others in any way....that is American! Let me know what you think. john
Well I sure tried to help. Below is part of the email from spitfirefrench.<hr />thank you for the calls
no I do not want to repair the engine because it does not worth, anyway he knows that it's bad quality.
I would simply ask for a refund, nothing simpler.
He does not answer my messages afraid to face the truth.
<hr />I kinda agree ...That was a huge chunk of money...and it may be true....the engine may be just thown together form other engines to make it look good, but may be next to worthless. Wish I lived closer to the seller....I would put pressure on him like a pressure cooker!!! I do think the seller should at the very least,honor the return of the money with the 15% restocking fee. I feel the buyer,s dismay. Capt,n
<span style="font-family: arial, sans-serif; font-size: 13px; line-height: 22px; "><span>even if it repays with 15 percent less, I agree because that is the agreement of sale on its site for the restocking fee. </span><span>(Well it is a winner because it can
</span><span style="background-color: rgb(230, 236, 249); color: rgb(0, 0, 0); ">scammed someone else after.
</span><span>but he must repay, because it is unworthy of a seller
</span><span>he is very fortunate to have received $ 3740, so 3740-15% = $ 3,179 I had collected.
</span><span>I note that its maintenance captinjohn is very nice person
. </span><span>and should be more people like that.
. </span><span>and should be more people like that.</span><span>@ + Aurel</span></span>
Capt,n
That was a really a great gesture on your part to get involved on a fellow modeller's behalf, and I do hope that this ends amicably for him.
Karol
Karol
