Spark Plug Cap Assembly Procedure
Old 09-06-2010 | 01:39 PM
All Day Dan's Avatar
Default Spark Plug Cap Assembly Procedure
I did some searches but I did not come up with what I need about the spark plug caps we use. I need an assembly procedure that includes dimensions and photographs that show the assembly procedure of the caps. Are there any out there? Dan
Old 09-06-2010 | 03:15 PM
w8ye's Avatar
My Feedback: (16)
Default RE: Spark Plug Cap Assembly Procedure
I've seen it in several places
I'm thinking it is on the RCEXL site too i'll look
Old 09-06-2010 | 08:50 PM
Try here http://www.dlenginesaustralia.com/do...apAssembly.pdf Capt,n
I just typed the question into Google search....works evertime!!!!!!!!!!!!!!!!
Old 09-06-2010 | 09:19 PM
Thank you Captain and Mr. Moderator,
I got the same page of assembly photographs but there were no recommended dimensions. I don't see the connection being made to the electrode spring or cap unless it's built in. Dan.
Old 09-06-2010 | 09:51 PM
w8ye's Avatar
My Feedback: (16)
Here's another
http://www.justengines.unseen.org/ac...lugcapassy.pdf
Old 09-06-2010 | 09:55 PM
w8ye's Avatar
My Feedback: (16)
Here's another 1/4-32 type assembly. If you look closely there is a spring inside the insulator that the resistor lead slides into
http://www.rcexl.com/news/Accessories/6.html
Old 09-06-2010 | 09:59 PM
w8ye's Avatar
My Feedback: (16)
Here's some more assembly pictures
http://www.rcexl.com/news/Accessories/14.html
Old 09-06-2010 | 10:08 PM
http://www.rcuniverse.com/forum/m_95...tm.htm#9513934
Old 09-06-2010 | 10:26 PM
w8ye's Avatar
My Feedback: (16)
In this picture if you look close you can see the spring inside the insulator boot of this CM6 size installation
[img]{akamaiimageforum}/upfiles/167062/Uq49938.jpg[/img]
Old 09-06-2010 | 11:28 PM
jedijody's Avatar
Demensions, which ones and what for? Is it a CM-6 plug cap or a different spark plug?
Old 09-06-2010 | 11:35 PM
My Feedback: (14)
Is the resistor lead supposed to penetrate the spring and be grasped by the coils? Or is it supposed to be simply pushed against the spring's coil? The latter sounds like RFI just waiting to happen.
Ed Cregger
Old 09-06-2010 | 11:41 PM
jedijody's Avatar
It is the latter, quite a few thousand units out there happily sparking away without producing any EMI issues.
Old 09-07-2010 | 05:45 AM
My Feedback: (14)
ORIGINAL: jedijody
I'm sure the EI unit wouldn't care. My concern is what the radio receiver thinks. As I have explained in other posts, we are dealing with a variable noise floor. Even in the best of conditions it can be forced quite high by extraneous RF sources. The higher the noise floor, the smaller amount of clear signal there is for the receiver to work with - even with spread spectrum technology being employed.
I would feel better if there was a way to solder the two together. One would then need a two piece nylon containment device instead of the one piece device currently used in the photos.
Ed Cregger
warbird72 (01-20-2021)
Old 09-07-2010 | 06:37 AM
w8ye's Avatar
My Feedback: (16)
The existing noise floor seems to be acceptable?
When the cap is properly installed on the correct size spark plug, the wire pig tail is firmly captured within the coils of the spring as they are compressed by the top of the spark plug.
Old 09-07-2010 | 08:11 AM
NM2K,
The wire can be inserted into the spring and be captured by it. That method is used in another type of ignition, similar in design, with no problems. Using that method you must be assured the urethane cap has no breaks that would permit the charge to arc over the inner boot to the outer cap.
Old 09-07-2010 | 09:15 AM
Some time ago Bosch did make a very goo metal shielded spark plug boots. I remember seeing them on small engines years ago! Capt,n
Old 09-07-2010 | 09:35 AM
MetallicaJunkie's Avatar
ORIGINAL: captinjohn
thats neat ... i always thought it was more difficult
Old 09-07-2010 | 10:22 AM
jedijody's Avatar
ORIGINAL: NM2K
ORIGINAL: jedijody
Ed Cregger
Pretty solid connections there, no arcing or possibility of vibration to cause RFI. Again, there are many thousands of units out there NOT causing any issues whatsoever with any radio system that has been used in the last 20+ years.
Old 09-07-2010 | 06:36 PM
These are all great inputs and just what I was looking for. I am amazed that there was no soldering required. Jody's description from a previous post says it all and his last image, a "cutaway" is perfect. Jody, not to change the subject, but will the RCexel ignitions run with the pick up on the Brisons or do they have to be changed? Dan.
Old 09-07-2010 | 06:42 PM
w8ye's Avatar
My Feedback: (16)
The connector is different
The CH has a Deans
RCEXL has a JIS like a Futaba, JR, and Hitec
Old 09-07-2010 | 06:52 PM
w8ye, I can live with that as long as I don't have to change the sensor. Hopefully Bill will get back in action soon and save all of us as he usually does. Dan.
Old 09-07-2010 | 07:50 PM
w8ye's Avatar
My Feedback: (16)
The older Brisons had a mechanical advance coupled to the carb, You don't need that with the RCEXL. You just fasten it in the full advance position for the RCEXL
Old 09-07-2010 | 10:00 PM
Pin outs are the same between the Brison CH and an RC Exl. Just change the plug.
Old 09-07-2010 | 10:18 PM
Thanks you two. If I can't get replacements for my C modules, I'll have to convert over to the ones with electronic advance. Dan.
Old 09-08-2010 | 12:46 AM
My Feedback: (14)
ORIGINAL: Tired Old Man
NM2K,
Yes, which would make a two-piece (split lengthwise) nylon containment boot very difficult, if not impossible, to employ.
T.O.M. Roger on capturing the wire withiin the spring. So what do we home assemblers do? Just live with the arcing that will occur with a simple push fit being employed?
Yes, Jim, there is some merit to your argument that this system has been working successfully for most folks. But it makes me wonder how many planes have been lost when a larger than normal gap occurs by someone pulling the boot end while holding the cable? That solder job is going to allow for some movement. It wouldn't take much to cause a problem. The metal cover will shield the spark somewhat. I'm worried that the gap of the plug combined with the gap in the nylon holding fixture could make the spark to the engine somewhat more unreliable than normal.
I'm an RF tech by trade. I don't like unsoldered, welded or non friction clamped connections.
Ed Cregger
