New Blade 500 3D Helicopter
Key Features
- Ideal for pilots ready to transition to high-performance 3D helis
- Engineered for aggressive 3D flight
- Belt-driven tail rotor with weighted tail blade hardware
- Spektrum AR6210 6-channel DSMX receiver installed
- E-flite 520H 1420kV brushless motor installed
- E-flite 70A S-BEC brushless ESC installed
- E-flite G210HL micro heading lock MEMS gyro installed
- Requires 6S 2800-3000mAh 30C Li-Po battery and charger
Overview
The Blade 500 3D BNF Basic is designed for intermediate-to-experienced heli pilots who want a big, powerful 3D machine they can simply bind to their DSM2/DSMX transmitter and fly. It comes out of the box equipped for aggressive 3D with an E-flite 520H 1320Kv brushless motor. This awesome power is complemented by the kind of state-of-the-art electronics and engineering you would expect to find in more expensive kits that take hours to build.Specs
Main Rotor Blade Length:425 mm Main Rotor Diameter:38.2 in (969mm) Tail Rotor Diameter:7.8 in (198mm)Length:33.5 in (850mm)Height:11.8 in (300mm)RTF Weight:4.06 lb (1.84kg)Last edited by larrygrela; 05-06-2018 at 04:21 PM.
Misleading AD
I felt compelled to respond to this AD so I will. The Heli pictured you are trying to sell is actually a Blade 450. I know I own 4 of em. Your trying to sell a Blade 450 in a Blade 500 Box. This is misleading.You go on to describe it as such as well. Even the Manual in the picture says "Blade 450 3D". This is not good selling tactics. Anybody else who sees this AD and knows the Blade line of Heli's like I do will agree. The AD is false and misleading. I reported this post. Sorry.
Issue corrected regarding Blade 500 3D
