Vintage Jemco Master Scale Series Douglas Dauntless SBD-5 R/C Model Airplane Kit
Kit is New but in open box
Has a span of 64 inches with length of 51 inches
Preferred engine size .60-.90
4-8 channels
Weight of 9-12 lbs
Kit contains: Five piece canopy each section molded separate for exact scale, flaps and dive brakes have all 318 holes made for you, Scale cowl with dummy engine, molded 1000 lb. bomb with die cut fins, complete plans for making the twin .30 cal machine guns, machine gun belts, four color three views, black line three views , four 36"x48" blueprints show how to do it all, in depth instructions, foam core with sheet, all Balsa constructions, built up ailerons and. Tail feathers, parts are all die cut, JEM LOC construction and beautiful decal sheet.
All pieces still in original plastic wrapping
4-8 channels
Weight of 9-12 lbs
