Futaba 14SGA 2.4GHz FASST Airplane Spec Radio ONLY NIB
My Feedback: (850)
MO
14SGA 2.4GHz FASST Airplane Spec Radio ONLY Brand new in the box, call text or email 314-256-9987 or [email protected] pay-pal ready or cc over the phone
Transmitter Specifications:
-2-Stick 14-Channel, FASSTest Air 2.4GHz system
-RF power output: 100mW EIRP
-Operating system: FASSTest 14CH, FASSTest 12CH, FASST MULT, FASST 7CH, S-FHSS
-Power supply: 6.0V HT5F1800B MiMH Battery
Receiver Specifications: NO receiver included PLEASE NOTE
-Receiver R7008SB
-FASSTest 2.4GHz system, dual antenna diversity, S.BUS system
-Power requirement 3.7V-7.4V
-Size 0.98x1.86x.56 in (24.9x47.3x14.3mm)
-Weight 0.38oz
Included:
-Transmitter T14SG for airplanes
-Receiver R7008SB
-HT5F1800B MiMH battery and charger
-Li-Fe spacer for optional FT2100B/ FT2F1700B LiFe battery pack
-Switch Harness
-Neck strap
-Instruction manual
Features:
FASSTest Air-2.4GHz multi-function 14 channel transmitter
Telemetry System
S.BUS/S.BUS2 servo setting function
Power saving transmitter type
SD card supported (card not included)
Unique model memory system
Mixing type selection
Digital trim
Lever head length adjustment
Switch/ VR position change and AUX channel function change
Trainer & Model data transfer function
-Receiver R7008SB
-Weight 0.38oz
Included:
-Receiver R7008SB
-Switch Harness
-Neck strap
-Instruction manual
Features:
Telemetry System
Digital trim
My Feedback: (850)
MO
Thank you Mike
314-256-9987
