Rebel Pro-2.6M NEW Ready to Bind n Fly
My Feedback: (26)
IL
Can deliver ready to bind and fly, or without PowerBox Royal, or without motor.
Plane has not been flown-Turbine has 1 run since received from the factory
Here is what is included
Rebel Pro-Red scheme
Wingspan-2.6 Meters / 102.4 inches
Length- 2.9 meters / 114.7 inches
PBS-TJ20A Turbine-230 Newtons / 51.7 pounds/thrust (new $5,800)
PowerBox Royal-power distribution system with LCD display, integral iGyro and GPS II (new $749)
PowerBox Bus splitter (1) for wings (new $50)
PowerBox Bus to PWM converters (3-new $54 each) 1 for each set of wing servos, 1 for elevators and rudder servos
Spektrum DSM-X Satellites (4)
Futaba S8157 Digital Servos (not HV) on all surfaces and nose wheel steering
JetTronics Electronic Landing Gear Valve (new $125)
JetTronics Low Loss Proportional Electronic Brake Valve (new $125)
Jet Model Products 2-Circuit Fill Valve Panel-4mm (new $289)
Stock pneumatic landing gear
Jet Model Products air tanks
BVM Hi-Flo UAT (new $85)
Fromeco Badger switch on ECU (ok for PBS turbines) (new $32)
(2) ThunderPower 2S 5400mah main batteries
(1) ThunderPower 3S 4400mah ECU battery
Custom Revloc padded and lined wing, stab and rudder bags (new $350+)
This plane is set up exactly like my other Rebel Pro. I don't need two so one has to go.
Turbine is new-1 run upon receipt from the factory.
Will deliver within 200 miles of Chicago-we can discuss if you live further away.
Will deliver to 2019 Jet Fall Classic in Rosewood, IN (by Louisville, KY). I will be there 9-12OCT 2019.
PRICE
Bind and Fly $10,400
Plane and Turbine $9,800
Plane only $6,800
PRICE
Plane only $6,800
